Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-13187432
Post #29,401 of 40,440
wakka992
  Hi guys,
I want to use iFi SPDIF ipurifier with coax input on mojo. As of now i'm using the optical spdif of the mojo but I'd prefer the coaxial input. Since the iFi product output is a "standard" RCA 75ohm coaxial plug, do you know any adapter/cable for FEMALE RCA 75ohm coaxial to 3.5mm ts jack 75ohm of the mojo?
Thanks in advance
Hi guys, no answer to my question so I'll change it: is a standard 75ohm coax RCA/RCA cable (such as the chord c-digital that I already have) going to work with the mojo if I use a RCA to mono 3.5mm (1/8in) adapter?
Otherwise I'll have to buy a new RCA/Mono Jack cable (and the chord one goes for a whooping 100£ minimum)
post-13187500
Post #29,402 of 40,440
willowbrook
How is everyone dealing with interference when running the Mojo in close proximity to their iphone? I get intermittent noise. I've tried different USB cables without any reduction. Was contemplating a short usb cable for a piggyback solution but now thinking I might want to stick with longer cable and different pockets.
Had that problem with my laptop while tethering via phone. I had these clicks that would not go away no matter what setting I switched or what cable I borrowed. Even borrowed a very short usb w/ ferrite beads on both ends. Gave up and got a gov2+. Never had that problem with any other dacs with the same laptop. Don't know if you are getting clicks or not, but try putting your phone in airplane mode. This solution should work. Although I never took the mojo outside with my phone and really never had any noise or clicking problem without a phone involved, it's a real shame that so many people are facing interference problems related to phone usage when the mojo is a portable dac/amp. Should be the first thing that should be addressed before anything.
post-13187523
Post #29,403 of 40,440
Light - Man
Dublin, Ireland
Dublin, Ireland
Age
120
That would be a much cheaper solution but ideally it would be best not to have an adapter in the equation due to theoretical reflections that it may create (but they may not be audible).
Can we assume that your source is a CD player and you want to include the iFi SPDIF ipurifier to see if it improves the sound.
The adapters are only a few pounds so would be worth a go.
post-13187538
Post #29,404 of 40,440
wakka992
Thanks for your reply.
Source would be a USB to Spdif converter, then to iFi SPDIF ipurifier then to MoJo/other DAC.
I'll buy a cable for the MoJo then...
post-13187559
Post #29,405 of 40,440
Light - Man
Dublin, Ireland
Dublin, Ireland
Age
120
If you have the cash to spare then it may be worth it (with the added benefit that you could connect the new cable directly from a CD player to the Mojo).
But, do you really need all that gear in the chain as they and the cables may detract more from the sound than they theoretically would benefit it. I usually find it best to keep things as simple and direct as possible.
Reactions: wakka992
post-13187576
Post #29,406 of 40,440
zerolight
Scotland
Scotland
No clicks, just occasional intermittent buzz of a mobile phone.
post-13187577
Post #29,407 of 40,440
wakka992
Don't worry, I'm crazy and I know it
post-13187588
Post #29,408 of 40,440
Light - Man
Dublin, Ireland
Dublin, Ireland
Age
120
That is a good start - at least you and I know it - many others here are still in denial
post-13188401
Post #29,410 of 40,440
TG04
Personally, I'm not there yet, but it was suggested in another post that replacing the battery in Mojo is fairly routine, any (authorized) Chord dealer can do it in a jiffy ... at what cost I'd like to know?  My unit is about to celebrate its first birthday and thus go off-warranty -- often that's when problem start!
post-13188466
Post #29,411 of 40,440
music4mhell
post-13188516
Post #29,413 of 40,440
wakka992
Ok, I've contacted a selle on ebay for a custom cable for MoJo... Now the question: how long should the coax cable be?!
The shortest the better? Or longer? Chord on MoJo site (http://www.chordelectronics.co.uk/support/dacs/hear-no-audio-output/i-am-using-mojo/connecting-coax-input/) suggest to use cable of 1,5mt or less to avoid connection problem, but they sell cable up to 5mt!
post-13188636
Post #29,414 of 40,440
Light - Man
Dublin, Ireland
Dublin, Ireland
Age
120
I  would opt for the shorter cable that would suit your needs and remember that good coaxial cables tend to be quite stiff and therefore may put stress on the socket in the Mojo over time.
I would probably opt for the cheaper adapter option as you are only experimenting to see if your set up improves with the additional equipment.
post-13188715
Post #29,415 of 40,440
miketlse
Dealers were charging $34 for replacing the Hugo battery, so I would expect similar or less for Mojo. http://www.head-fi.org/t/702787/chord-hugo/13995#post_12965364
Users Who Are Viewing This Thread (Users: 4, Guests: 13)
