jonlad1
- Jul 28, 2014
So what is the best/safest type of charger to use? 5v 1.0A?
I'm just planning on using stock standard Samsung phone chargers (5v1A).
Is no one buying the Mojo and free case from Audio Sanctuary?
ROB - Now one of the safety circuits is a safety timer, and this is when the charger is in full charge mode. This timer is set to about 8 hours, and normally full charge mode takes 4 hours, when the unit is off. But when the unit is on and playing, there is a risk that the safety timer will be set, as it can take 12 hours to fully charge (from flashing red) and when playing music (for those 12 hours) at the same time. If the safety timer is set, then the battery LED will slowly flash white, and no further charging will take place. To reset the timer, just disconnect the charge USB, wait 10 seconds, and reconnect, and it will recommence charging.
I'm just planning on using stock standard Samsung phone chargers (5v1A). Not sure I have a 5v2A
Ok today out with the Hugo on same street, train, bus as with the Mojo. Using same headphone and EQd the heck out of the hugo. 50% loss of bass out and about. Clear mids and treble but bass not hitting. Either due to leakage from HP and lack of bass punch. Yesterday with a portable amp perfect bass outside with the hp.Mojo does just fine (great actually) with my LCD-2.2, and yes, I've compared driving the Audeze from many different sources included the ones in my profile that I currently own, and others I've sold or demo'd.
Curious if you feel the same about your Hugo, since the Mojo shares the same power output (Current and Voltage and output impedance)? Also, the term 'does better' is so ambiguous. It would be helpful to describe 'better'. I have no want for an external amp when driving headphones from the Mojo when I'm not at my desktop rig. Of course preferences and all that not accounted for. YMMV.
Does Mojo stops flashing when fully charged? Charging new Mojo since 12 hours on 5V/2A and still blinking.
