Mojo has over-voltage protection, but I suppose it may not be absolutely impossible to cause harm, if a 'turbo' mode USB charger is used, that may have flakey sensing/communication firmware (necessary to determine whether or not it is safe to use 'Turbo' high-voltage charging mode), particularly if plugged-into Mojo on a regular or continuous basis. Even with a well-implemented charging chip, incorporating over-voltage protection, there is only just so much abuse a protection circuit can withstand before eventually failing, if a charger is failing to ensure it definitely does not exceed 5V with devices, such as Mojo, that require no more than 5V charging supply.
In spite of people being repeatedly recommended to use simple 'dumb' fixed 5V chargers, some people seem absolutely determined to use fancy 'Turbo' chargers that, given an opportunity, may try to send higher than 5V through the microUSB port.
Although Hugo does not employ USB charging, I recall Rob saying something related, in relation to [COLOR=FF0000]Hugo[/COLOR]:
Rob did remark, specifically in relation to [COLOR=FF0000]Mojo[/COLOR]:
Although I am only speculating about the above possibility, it would certainly be interesting to know, @ jadeboy & @ citraian, if you have been using chargers capable of exceeding 5v output, when charging Mojo,
