- Jun 8, 2009
How does toslink sound with the mojo?
no eq and most hear dont like strong bass. Plus many love Celine Dion and ABBA.How does toslink sound with the mojo?
So I finally picked up the mojo. Bought it from Audio Sanctuary in the UK.. They had it for 332.50 lbs which came out to $450. Not a bad price.
http://www.audiosanctuary.co.uk/chord-electronics/
Upon first listen, bass seems to be pretty light. I hope this resolves itself upon burn in. It is really open sounding though. It took a while to get it connected to my android. Worked flawlessly out of the sony zx2 the first time.
I stream mostly tidal hifi. I would like eq though, which tidal doesn't have. I've read about amarra for tidal, which is only for mac it seemsl. Does anyone have experience with it on the phone using eq? Does it work? Are they other alternatives?
Just got the zx2 a couple of weeks ago, now the mojo. If the mojo's bass doesn't improve, I'm going to sell it. I have too much gear and need to start selling some off.
332 lbs... Was this a special edition 'osmium' Mojo? Hate to think what shipping costs you paid for on that
Never thought of the Mojo as lacking in bass, and I mainly listen to electronic, EDM, rock and the like.
332 lbs... Was this a special edition '[COLOR=222222]osmium[/COLOR]' Mojo? Hate to think what shipping costs you paid for on that
It sounds very good. I preffered the optical input on the Mojo with exotic cables until I used higher sampling rates with ASIO drivers and stock cable of Mojo. Problem is optical it only samples upto 96 kHz vs. USB which can sample upto 384khz. I hear the difference and prefer USB over optical now on playing music through streaming services.
@talan7, I use a small coaxial cable between fiiox3 ii and mojo. I opted to get 4 pole trrs and 2 pole connector from market and soldered a small cable as per the polarity of fiio x3 ii. in India it is difficult to get ready made mojo to fiio x3 ii cables. I put few small ferrite chokes on the cable and I would say it made very perceptible improvement to the background.
Who told you optical only goes as high as 96khz? :blink:
Try a higher-quality toslink cable. You should get to 192khz without a problem.
Same here. My Lavricable has been my go to portable cable and with the new iOS update....nothing. Restarting did not help. It does not recognize the cable.
I have had great customer service with Lavricable so I think we will hear from them...
