EagleWings
I started a project to try and build a part to hold both my Fiio X3ii and Mojo, in a side by side fashion, as I am not a fan of stacking. The final part I was trying to design, would hold both the devices in tact and, the entire unit could be handled as a single device like a tablet or a portable gaming console.
This is my project: https://www.you3dit.com/projects/base-plate-for-chord-mojo-and-fiio-x3ii
Here is the schematic:
I couldn't see through the end of the project because, the Fabrication/Laser Cutting process is pretty expensive. I even got the 3D model designed. I can't upload the .STL file as the site doesn't allow/support it. PM me if you are interested in this and need the .STL file. The part could work with a X5ii too.
Since I couldn't get that done, I put together something similar out of lego blocks. I will be shortening the cable by an inch or 2, so that it does not form an arch.
