Not meaning to take the thread off-topic, but since we are in the business of seeking quality audio, I thought this is something that might be worth knowing/sharing:
Thanks for the cable information and link. By the way, what is the length of your cable? and what will be the optimal cable length if two units are placed side by side?
Unfortunately it wont work with the 1st Gen Fiio DAPs either, as it is a stereo cable and not a coaxial cable. Stereo cables carry analog signals and coax cables carry digital signals. A coax cable that size would be lovely though.
Sorry for calling your statement wrong. Just learnt in the post below that the stereo cable can still be used for digital connection.
False. There is no differentiation between digital voltage and analogue voltage besides one being sampled and one being continuous, and amplitude (The definition of digital is Sampled Data vs Continuous data for analogue). The wire doesn't care what label we put on the voltage. I've used a regular stereo interconnect from the 1st gen X5 to the Mojo and it works fine. I also can't reliably hear any difference between this and a 'proper' coaxial cable. The copper wire doesn't care if it's an analogue voltage or a sampled digital voltage. It will still pass along the signal. The difference is in the shielding and cable resistance. This will affect noise and ringing, especially at longer lengths, but at these short lengths the audible difference is zero to my ears. Of course others may hear a difference, but if going on the cheap it will and does work. Also, many iBasso owners have reported this to work as well.
I understand the confusion. No worries, it's a common misconception. The coaxial cable was developed specifically for extremely long lengths (like miles), and to be shielded from powerful EMI/RF, but audio seems to be more susceptible to longer length signals so it's often used even for 3' runs. These short lengths being used with the Mojo, without the proper resistance and shielding, don't seem to be affected audibly, although there may be measurable differences. I just can't hear them. YMMV, so the best advice I can give is to try it vs a 75 Ohm S/PDiF coaxial cable yourself.
You only need a custom TRRS to TS/TRS cable if your DAP has a shared coaxial/line-out jack like the FiiO X3ii/X5ii/X7. If getting a custom cable just tell them what devices you are connecting and they should give you what you need. If not, don't use that cable maker. What DAP do you have?
To all Onkyo DP-X1 users, how do you stack mojo with DP-X1 and how do you carry them around during portable use?
I looked over everything (budget-friendly options) from 3M Double Lock, rubber bands, pelican case, other cases on the 3rd post and searched posts, but I can't really find one good method...
I'm going to buy Fiio X3ii as the transport. Do I connect TRRS plug to Fiio X3ii or to Mojo? By the way, I have a cable with TRS plugs on both ends. Will it work to connect FiiO to Mojo?
As I've tried to explain, you need to connect the TRRS to the X3ii because the X3ii/X5ii/X7 share the coaxial out with line-out. Mojo's end is TS. The ONLY time you can get away with using a regular TRS interconnect is with a DAP that DOES NOT SHARE the coaxial output with the line-out.
This is the Dyson Audio cable I use with the X5ii - TRRS from X5ii to Mojo TS:
I think some confusion is coming from the fact that the previous cable that was posted has a TRS right angle plug, but that doesn't mean the cable maker needs to wire it to all three poles. Like I said, just let the cable maker know which device you are connecting to the Mojo and they will solder it properly.
