simonm
- Mar 26, 2007
Is UAPP the only app to stream Tidal hifi?
You mean apart from the Tidal app?
One last thing before I purchase MOJO: does it work with MOOV (both iOS and Android)?
what is moov?
ye. If I use the Tidal app then the mojo still upsamples the music to android or use my phones DAC etc however it works. It gives me a blue colour globe. If i use UAPP it gives me a red globe. Does onkyo, N7 etc also give me access to Tidal where it doesn't upsample the music?You mean apart from the Tidal app?
Out of curiosity, do the Android based AK players output bit-perfect through optical? I am asking because, I've read that the Android OS up-samples the data. Or does the up-sampling take place only if the digital output is through USB?
Thanks!
Most would find the extender accessory unnecessary if using an aftermarket cable like the one offered by Lavricables. The extender accessory, however, is also supposed to come with a USB OTG cable and it may make stacking better (ergonomically) for some. I really can't say if it will work with other aftermarket cables or not as I haven't tried one. Looking at it, it seems that it wouldn't work to me given the extra length it adds, but I really don't know.
Btw, the add on looks much better now from the prototype as seen in EagleWings link:
What is that for extender?
Never seen before, where did you get it?
Come with extra battery?
It's an add on accessory to 'swallow' the official Apple CCK required to extract an audio signal from Apple IOS devices. There is no extra battery and has no other function. There is more information in the 4th post of this thread in the 'Forthcoming add-on module' section.
I don't have this, I was linking pictures to a link provided by member EagleWings.
Thanks for the clarification
I just hope mojo has adapter for 2.5mm balanced output wow
so if I used mojo direct through the Tidal app out of my phone, the SQ will still be great regardless?The sampling rate ball on the Mojo only indicates what sampling rate it is receiving, not what it is up sampling to. The Mojo, with the WTA filter Rob has spent so long working on, has much more processing power and up sampling capability than any mobile device, which is why Rob says you should not up sample from the source. There is a lot of information in the third post regarding this.
