jeenam
- Aug 12, 2008
This message post is for folks who are using the original Mojo, or really any USB interface device that does NOT have volume control with MacOS. OP - if you're reading this, add it to the FAQ.
The geniuses over at Apple don't include any built-in functionality to control volume for output devices such as DACs. To say this is stupid would be an understatement because the functionality is built into Windows. I had searched for months for a workaround and came across a few solutions, all of them paid at ridiculously stupid costs of $30-$40 such as Soundsource and SoundControl. There's a free utility called BackgroundMusic but it routes audio internally to a virtual microphone device which causes MacOS to display the stupidly annoying and bright orange icon in the menu bar. Randomly I came across a reddit post for someone who created a utility that solves the volume control problem for DAC's with MacOS - AND IT'S FREE.
*shakes fist at Apple and the greedy devs of Soundsource and SoundControl*
https://www.reddit.com/r/WeAreTheMu...made_a_utility_for_the_mac_that_lets_you_use/
The link to the software is https://github.com/briankendall/proxy-audio-device.
After installing the software, reboot your Mac. Then open the proxy-audio-device settings app and select the Mojo as the Proxied Device. Set the audio output on your Mac to 'Proxy Audio Device'. Now you can control the volume of the Mojo on MacOS using the volume slider or the volume keys on your keyboard.
