I had said this many pages ago as well.Totally agree xfeed boosts the mid-bass ever so slightly
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
jarnopp
- Nov 26, 2014
All this cable talk again, but I just confirmed that an adapter like this works to send lossless from iPad usb-c (via Roon) to Mojo2 over toslink. Can’t wait for a usb-c iPhone! https://www.amazon.com/gp/product/B07VSFBT82/
Edit to add that optical is supposed to be the reference connection (if you don’t need over 192kHz) anyway, and so cheap for this adapter plus a toslink connector of your choice of length!
I received two emails about this: one because I registered my Mojo and one because I registered my Poly, they at least didn’t send me one because I registered my Qutest.Both the Mojo 2 and Poly are £100 off at Chords U.K. dealers until the 31 August 2023.
One would have been enough.
miketlse
- May 8, 2016
'I received two emails about this: one because I registered my Mojo and one because I registered my Poly, they at least didn’t send me one because I registered my Qutest.
'One would have been enough' but unfortunately some IT coding/practices are not always sufficient to achieve this.
Solarium
- Oct 19, 2013
Can the Mojo 2 power the HD800S sufficiently?
MgMGM
With Mojo OG , as an extra Chord sold an accessory pack with all the cables your likely to need. Included was a USB module , that looked just like the poly and had a slot to connect the Apple lightning adaptor into. This eliminated the short USB A to Micro B cable and made the whole set up very convenient and very robust......Be good if Chord made them for the Mojo2. It would stop the white noise issues.(forgive the small rant)
My current frustration is with OTG lightning to USB-C cables - they keep breaking. I've been through three so far, two generic ones and one DDhifi Mfi06.
I try to be as careful as possible when on the move but obviously that's not always possible, especially during crowded commutes. But I didn't imagine they'd be this fragile! none have lasted more than 2 months.
Ordered another ddhifi coz it's a genuinely good cable, and the Cayin RU6 one to have a back up.
In the interim, I'm using the Apple lightning to USB adapter with a generic USB A to C cable - works (and feels fairly robust) but ungainly and unwieldy.
Anyone else experience high failure rates with OTG cables?
banani4000
Quote from the Headfonia review of the Mojo 2:Can the Mojo 2 power the HD800S sufficiently?
“The Sennheiser HD800S and Mojo 2 combo is excellent. I didn’t expect it to sound this remarkable but I could listen to this all day long. Clarity, precision, excellent PRaT, a good amount of overall body, nice bass impact and all that with a musical presentations. My ears approve.”
Full review: https://www.headfonia.com/chord-electronics-mojo-2-review/4/
davehutch
- Aug 10, 2009
Can I just clarify something if you wouldn't mind?
1. Am I correct in saying that a Poly will allow me to Airplay from my Mac and iPhone to the Mojo 2 at 24/48 Lossless if my local files are 24/48?
2. Am I also correct that if I use Apple Music it will be converted to 256 AAC first for some reason?
TIA
TIA
Yes very well.
You can. But the bass would be anemic. Put HD800s on a cheap tube amp like TA-26 and you’ll see how much more low end you’ll have.Can the Mojo 2 power the HD800S sufficiently?
evhvis
- Jan 28, 2013
The adapter still fits mojo 2, which is why you still have 2 micro ports on the mojo 2. Not sure if the adapter pack is still sold though.With Mojo OG , as an extra Chord sold an accessory pack with all the cables your likely to need. Included was a USB module , that looked just like the poly and had a slot to connect the Apple lightning adaptor into. This eliminated the short USB A to Micro B cable and made the whole set up very convenient and very robust......Be good if Chord made them for the Mojo2. It would stop the white noise issues.
whoa you just reminded me I have one laying around! got the cable pack when I bought the OG Mojo but it's been tucked away in a drawer somewhere since I got M2. Time to dig it out, this may be a good solution. thanksWith Mojo OG , as an extra Chord sold an accessory pack with all the cables your likely to need. Included was a USB module , that looked just like the poly and had a slot to connect the Apple lightning adaptor into. This eliminated the short USB A to Micro B cable and made the whole set up very convenient and very robust......Be good if Chord made them for the Mojo2. It would stop the white noise issues.
Yes the frustration of not being able to comfortably listen to M2 on the go, without carrying unwieldy cables, is what's getting to me. At one point I had to revert back to an Apple dongle... fine but obviously not the sameQuite early on with Mojo 1 I had this experience. The cost to replace the cables was one thing, the sheer frustration at not being able to listen to Mojo when I wanted was too much. That drove me to buy Poly. It ended up being a great decision
Isn't that too bulky on the move tho?All this cable talk again, but I just confirmed that an adapter like this works to send lossless from iPad usb-c (via Roon) to Mojo2 over toslink. Can’t wait for a usb-c iPhone! https://www.amazon.com/gp/product/B07VSFBT82/
Totally agree can't wait for usb-c iphone, enough with this lightning nonsense...
dericchan1
I was just about to say that thing look so bulky and that Chord accessories package is so expensive!!!Isn't that too bulky on the move tho?
