Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
May 24, 2023 at 5:58 AM Post #8,236 of 12,424
PC / Notebook
With PC you can get get optical back plate and wire for less than £20. Alternatively even HS01 is well up to the task.
On notebook,straight USB is fine. laptops are not grounded, therefore ground loop can't occur.
If using headphones, then straight USB is again fine. Headphones too, are not grounded.
May 24, 2023 at 6:04 AM Post #8,237 of 12,424
I have problems with DSD playback (at least in Foobar, didn't test other players). I have this file and SACD plugin installed (it's played and recognized correctly), but the circle on my Mojo2 is lit red instead of white (for DSD). Is the file decoded correctly by Mojo?
May 24, 2023 at 8:39 AM Post #8,238 of 12,424
Vodafone is turning off the UK 3G network in June. That means no more interference when the mojo is connected to the mobile via a usb cable
And goodbye to my data connection at home. There are far too many places in the U.K. that still only have 3G.
May 24, 2023 at 4:54 PM Post #8,239 of 12,424
I haven't owned a mojo for a while, but the interference is more likely from 2G due to the TDMA modulation. If 4G & 5G coverage isn't very good (as in the UK) devices will fallback to 2G and you'll get more interference. 2G isn't going to be switched off until something like 2035.
May 24, 2023 at 6:35 PM Post #8,240 of 12,424
I have a question.
Is it better to use the Mojo 2 with 19200 Samplerate and higher even when i listen to 44100 Samplerate music through Foobar?
Or should i use 44100 hz like the standard music rate?
thx
May 24, 2023 at 6:54 PM Post #8,241 of 12,424
I have a question.
thx
Has been asked a few times before. You could have searched for it.
Supply it bit-perfect (i.e. 44.1), do not resample.
Let Foobar change sampling rates automatically.
May 25, 2023 at 10:47 PM Post #8,244 of 12,424
I use Chord Mojo 2 to drive my Focal Radiance, with some crazy EQ settings:
Base. 20Hz + 3db.
Base. 125Hz + 5db.
Treble. 3KHz - 5db.
Treble. 20KHz +1db.
Outrageous settings. Should I leave the room now?
All bass and no treble makes Johnny a dull boy!
May 26, 2023 at 10:10 AM Post #8,246 of 12,424
If music is playing through the Mojo normally when you play it, then your computer is re-sampling it to PCM.
May 26, 2023 at 10:38 AM Post #8,247 of 12,424
Anyone have any Mojo2 EQ settings for the Liric they recommend?
May 26, 2023 at 10:51 AM Post #8,248 of 12,424
Set the output device in foobar settings to chord mojo. The chord mojo windows device driver must be installed.
May 26, 2023 at 6:40 PM Post #8,249 of 12,424
Looks like I solved the problem. In SACD settings I had to change Type to DSD. For some reason it won't play DSD files through WASAPI output - there is terrible distortion instead of music. It only works with ASIO.
