Carl6868
- Dec 10, 2011
Ok, i tested again a Note 3 and S6 phones....
S6 has a native support, note 3 does not. both Lollipop
problems are still there,for both phones, there's a subtle distortion, clicks and pops during playback, but even in background
with mate 7 distortion is much more hearable, so that should be a phone problem.
Anyway, mojo is definately NOT and android phone friendly DAC.
even my DAC1 of many years old can work with android, that doesn't mean it's an android dac.
just making more tests, the Fiio E18 pc mode out works with the otg adapter, but not with the included micro to micro cable.
this means 2 things:
E18 micro to micro cables are not really otg cables, or are made to work with fiio E18 phone mode only.
then, MOJO is just an USB DAC made for pc, with wanna be android compatibility mode, and that means it draws power from battery phone or it's prone to noise .
it may be prone to glitches, even very very subtle glitces, difficult to hear when on the go and without a carefull listening session.
with galaxy S6 and a longer cable and airplane mode, glitches and digital noise are still really subtlelty hearable, and accurately comparing the sound quality when connected to pc, it's evident.
with pc the mojo is smoother and better sounding. and it is a funny finding knowing that it is not galvanically isolated.
fiio E18 is really an android/mobile dac and well engeneered for portable use with USB devices.
MOJO is not, and it sucks when usb connected to phones.
that's the end of the story
What a load of rubbish, I use the Mojo with a Samsung Galaxy S4 - No problems, Moto X Force - No Problems, iPod touch - No problems, IPad Air - No Problems only issue I had was with UAPP dropouts initially but adjusting the buffer size cured that.
