Pocomoto
When I dissected my defunct mojo battery I found it had a single small protection pcb inside the pkg. Does the 2000mAhr replacement battery have this?
Yes, it does have it.When I dissected my defunct mojo battery I found it had a single small protection pcb inside the pkg. Does the 2000mAhr replacement battery have this?
Is your Mojo connected to a headphone via the autoformer?The 1500mAhr battery I got doesn't last long, but I am wondering if it is because it's driving an autoformer vol control.
Or is the autoformer sitting between Mojo and an amp?
- If you are using headphones, seriously think again! because the output stage on Mojo uses feedback and has a very low impedance to drive the headphones.
Anything between Mojo and Headphones would cut into that, besides the volume control on Mojo works on highly resampled digital data, and according "Audio Science review" who incidentally are not friendly with @Rob Watts or Mojo, it was tested and its linearity was one of the best they had ever tested on any equipment!
The autoformer is a very good passive volume control, to be used in an amplifier, since the input (or interstage) section has high impedance and no direct feedback point.
That's another discussion for another time.ASR just tells it like it is. They are not friendly or unfriendly. Just honest.
Well doneThat's another discussion for another time.
Between the mojo and my amp. When using headphones I connect the mojo direct to headphones. Is there any reason the mojo would not like an inductive load (about 100H). They are Slagle AVC from Intact Audio.Is your Mojo connected to a headphone via the autoformer?
I wouldn't know, but 100 Henry is huge! are you sure?Between the mojo and my amp. When using headphones I connect the mojo direct to headphones. Is there any reason the mojo would not like an inductive load (about 100H). They are Slagle AVC from Intact Audio.
Don't know about your link, if it is the same as I had mentioned earlier (actually from @Julius Decimus I believe), then it behaves good.
I have had it in my Mojo since I last reported.
It charges fine, does not heat up, I get normal play time from it, though I do not time it any more, but last time I did, I got (USB) 8+ hours feeding my not-so-efficient Hifiman Sundara's.
I reckon one would get more play time with efficient headphones/IEMs and not using USB (for some reason Mojo uses a little more power on USB input).
Overall, nothing bad to report - it is working fine.
Sundara works with Mojo.How do you find the Sundaras/Mojo pairing?
I'm planning to get my first decent set-up. I've decided on Sundaras, but contemplating the Chord Mojo, Earmen Sparrow or Earmen Colibri (due out in '15-30' days I was told).
There seems to be just an handful of Mojos left. I would also be keen on Mojo 2, but it appears to be under wraps with no confirmed release date.
Mojo + Sundara is very Dry sounding. iFi is a better pairing. The XD-05 Plus (with V5i) is also a good pairing. I've ordered and will get the Sparrow in 4 days, I can PM you on how it performs if you are interested.How do you find the Sundaras/Mojo pairing?
That would great - thank you. I wasn't sure if the Sparrow would sufficiently power the Sundaras to their fullest potential - so I'd appreciate your findings!Mojo + Sundara is very Dry sounding. iFi is a better pairing. The XD-05 Plus (with V5i) is also a good pairing. I've ordered and will get the Sparrow in 4 days, I can PM you on how it performs if you are interested.
What do you exactly mean by “dry” sounding?Mojo + Sundara is very Dry sounding. iFi is a better pairing. The XD-05 Plus (with V5i) is also a good pairing. I've ordered and will get the Sparrow in 4 days, I can PM you on how it performs if you are interested.
