Possible Ideas for a Mojo-II (if one in pipeline!)
- Just humble suggestions for a possible new version.
Robwatts has said he will not do minor upgrades, it has to be sound quality based before he does it.
Also I remember reading his notes on Mojo design, and he explained about his milliwatt budget, heat dissipation and how he is not using the full capabilities of the existing FPGA chip because of the Budget and heat generation.
- Furthermore, the coloured marbles on the Mojo can be loved or hated, however since it is part of CHORD's look, I suppose we should accept them.
I really think that Hugo 2 form is more functional than Mojo's - so here is my suggestion.
Lets make the marbles a little smaller and move them to the side, while we are at it, lets do away with slanted CHORD logo.
It would give us a more square box, leaving more room inside for a larger battery (to help with our milliwatt budget).
Doing away with the dated TOSLINK and combining it with the existing COAX socket, means we could move the headphone socket to its place, and frankly one is enough!
If anybody likes to share, they can get a splitter from the pound shop (Dollar-shop).
The above opens up a lot of space inside.
By turning over the board, the bottom shell can easily double as a heatsink for the input chip and the FPGA if one thermally bonds them to it.
Did anyone notice the USB-C charging port?
These days fast USB chargers are everywhere using a type-c cable. They have a native 9V output, this means that Mojo atleast will not need the noisy , heat producing switch-mode charging circuit, so not only it can charge the battery faster, but a lot cooler too!
Now that the heat issue is somewhat resolved, and we have more room inside for a possible 2500 mAh battery (instead of current 1650mAh), Robwatts can utilize the full potential of the FPGA chip, to improve the sound quality we are all after.
What do you think?
