dontfeedphils
I wonder whether it works the same way as apple? Do android phones require a chip in the connection piece? I know apple devices require one and by using the CCK (which has one incorporated) you can connect any other cable. If it doesn’t require a chip then in theory any cable would do
Android doesn't have any of the requirements Apple does when it comes to cables. I think OTG is less important with USB-C as USB-C should easily communicate both ways. I believe Micro-USB requires OTG to tell the device it's in "host" mode.
I might be completely off-base though, so don't take my word as gospel.
