Julius Decimus
- Aug 7, 2014
Yes, its great for metal and rock (that is what i listen most). For classical as well. For anything i would say.K712 Pro is much cheaper than all the other options I was considering ... I could also find a slightly used one, a few months old, for 150 €.
I'm reading some reviews and opinions, the huge soundstage is something I really like, it shouldn't be too tiring on the treble ... with faster and heavier genres like Metal does it work well?
This is open back headphone. Soundstage is bigger/wider than on HD600 series in comparison.
Has a easy changable cable. If gets damaged or you want shorter/longer one, you can change it.
Has a easy changeble pads as well.
Very large pads, its comfortable.
I don't see/think there are any downsides. Up to 4-5x price, i don't think there are better sounding headphones.
If any other questions, ask.
Edit: Good for EQ as well. If need. Treble is good.
