miketlse
- May 8, 2016
Unscrew the base of the Mojo, and inspect your battery.greetings
i have mojo poly, and my mojo is bout 2 years old when i charge it fully while turned off it gives 4 hours playback
now when i connect it to the poly and both are fully charged, i noticed that after fully charging them and not even turning them on, after a day while not being used that poly battery is blue while mojo is orange, how can this big discharge happen so fast
any recommendations
- If it is swelling, the battery is on the way out, so remove it and put it somewhere where it will not be a fire risk.
- If the battery looks normal, you can continue to use it.
