LightBlue77
cool, thanks, then there should be no problem while streaming mqa files via uapp.
thank you, i have a v20.
i don't have to much knowledge about unfolding, i'll have to read about it, but i assume you mean the hardware mqa builtin support that v30/v40 have, right?
Are you thinking of buying a Hugo 1?ok, thanks, how about Hugo? there are 2 micro usb inputs on it, i read somewhere that one of them is the normal DAC input for whole range of sample and bit rates and the other is for smartphones and tablets but is limited to cd quality. is this true? i think i should ask this on a hugo thread ...
The Hugo has been out of production for 4 years, so you would be trying to find one of the few remaining new Hugos at a dealer, or buying second hand.Yes, why?
Actually, i am undecided, mojo or hugo.
If you go down 4 clicks that will be 1.9VRMS which is closer to true line level output. Plus should give you more volume range on your amp.I am using Mojo with line out and feeding it to Valhalla2 or Monoprice Liquid Platinum. I don’t own any Preamp right now, however at line level I find it too loud with amp volume at minimal with HD800s. Can I go down with Mojo volume control to give me more room for volume thru my amp, will reducing volume thru Mojo in any way reduce the sound resolution?or do I I have to invest in preamp like Schiit SYS.
had this in the beginning as well (2015, got mojo first batch), turned out it was the usb charger that was producing the high pitched sound. changed to a better one, haven't had a problem since then.does anyone's mojo have a high pitched whirring sound during charging?
for some reason my mojo does after couple of weeks from purchase
sound only stops when i unplug it
no whirring noise when in USB mode
i only charge when device if powered off
That's quite a big difference. I would just get the MOJO.I found a hugo sold by someone, also a good as new mojo. I am not yet sure the price of hugo it's worth the difference. What do you think? 350 vs 800 euro.
