Amberlamps
Formerly known as Phuca
- Jan 22, 2017
Dear friends,
I use Chord Mojo as desktop dac.
My system is Chord Mojo > Naim Nait 5i-2, Dali Ikon 1 MK2 speakers.
I know that Mojo has line level output (~3v volume setting). But should it sound the same or different when feeding external amplifier lets say at 1V (green or yellow colour or any else which is much lover than line level)? Maybe @Rob Watts or anyone else from Chord could explain or share their experience on this. Is line-level output volume level is best sounding when Mojo is used as dektop DAC.
Another question, do you think that listening at very low levels Mojo driving straight external speakers shoud sound better than through my for ex. Naim Nait 5i.?
Thank you very much
@Rob Watts
Mojo’s line level out, is that the same as just turning mojo’s volume up to the maximum or does enabling line level mode also give more voltage compared to maximum volume.
Can Mojo have it’s battery removed, say it was no longer charging good and an owner just wanted to remove the battery and plug mojo into a charger all the time and use it that way, would mojo work properly that way ? It’s just a hypothetical question. Cheers.
