dennistdk
- Aug 9, 2015
That looks brilliant. I wish I was that tech savvy.
Thanks. It was only like soldering 4 wires to the Pi zero w - anybody can do that.
Presumably you have to program the Pi though. Fancy making me a unit to run Tidal? For a fee of course.Thanks. It was only like soldering 4 wires to the Pi zero w - anybody can do that.
Not into taking commissions?I haven't used Tidal in a while, but the "moOde audio" software that you just load onto the SD card should support Tidal streaming: http://moodeaudio.org/ (look under features).
I have looked multiple times and do not see something that answers my question? I'm not trying to bypass the CCK. Maybe i'm blind.Maybe have a look at FAQ's in the third post?
Well if you are ever up for it. PM me. I'm pretty easy going but would enjoy the experiment and interaction.Hehe. No, don't think so. Just in it for the sharing
I also don't have the parts right now for building an extra.
Really sorry man. I honestly wasn't trying to be rude. I genuinely thought the FAQ would help. I use a Zee Audio cable that was pretty cheap. It's excellent but they seem rather elusive on the net. Mine bypasses the CCK for IOS but I'm sure they would do a cable to suit your needs.I have looked multiple times and do not see something that answers my question? I'm not trying to bypass the CCK. Maybe i'm blind.
Hi @Rob Watts
Regarding JA's Stereophile Chord Mojo measurements a couple of years ago - did you ever get a chance to discuss his 16bit TOSlink jitter measurement (see below)?
What's the cause for the little hump? I know it's all at a very low level anyway and likely inaudible, but just curious if you discussed it with him.
https://www.stereophile.com/content/chord-electronics-mojo-da-headphone-amplifier-measurements
Wait a minute there, i thought it was immune to jitter on all inputs?
Hi @Rob Watts
Tests using 2 uS of source jitter revealed no output change at all, so Mojo is indeed source jitter immune.
I have read that astell & kerm are excellent transport for the mojo and that the sound of the mojo varies depending on the digital transport.
beyond the practicality of the M1 shanling you are sure that it makes good transport for the mojo? better than an astell & kerm?
