Yes as that is very high impedance load, so negligible signal currents.
Thanks Rob. Got a reply from a local retailer that they carry the replacement battery and I should be getting one by tomorrow.
If I'm working with a Mojo that I picked up used and could likely be ~2 years old, would it be a good idea to open 'er up and check for battery bulge (naturally, the aim being to avoid any damage to components buy unchecked battery growth..)?
Yes you definitely should. Just get the right bit head and remove the 8 hex screws. Inside, the board is held onto the bottom plate by 2 regular Phillips screws.
TBH, I was really surprised my amp board wasn't damaged even though the battery was bloated badly and applying substantial pressure. Cannot imagine the harm it could have done if I waited any longer.
Where did you get the battery and what is the price?Just got my battery replaced. Everything good as new now...
I bought the last piece they had from a local retail store for SGD$90, which translates to about US$65.
The prices people are paying out there for the battery and replacement service varies quite drastically. For my case I only gotten the battery pack and replaced it myself.
Glad you got sorted out.I bought the last piece they had from a local retail store for SGD$90, which translates to about US$65.
jaben ah?
What direction works best? Right or Left braid?Here you go ...
Curious why you need spares.Hi Rob, is there any way to get spares for the balls (buttons) on the Mojo?
