GreenBow
- Feb 6, 2015
Very interesting feedback from you, thanks.
Still testing (enjoy) the Mojo in both ways, as only dac (line level) on my main system and as dac/amp for my hd650 (iphone as source, tidal).
As dac is currently a winner (and i am using a very cheap cable actually) apart the high end that maybe i need to get used to it.
As also amp, instead, while I am aware about all the benefits of it in term of overall resolution and “tune”, I somehow miss the impact punch slam fullness that i got from my desktop dac amp.
These are still my feedbacks.
I hav two questions:
1) the jitterbug is really interesting? I can easy have it from amazon.
2) with a lower impedance hp i could have better results or otherwise with a dedicated amp (bh crack, etc.). I mean not in SQ but i mean in “filling” more powerful the hp.
Well you may find the Mojo grows on you more still yet, and I think you will. It might be case of either accepting the Mojo's signature. Or that you recognise the Mojo's slam is the right amount.
The JitterBug is a good idea I think. It might be a good plan to get comfortable with the Mojo. Then make another purchase, but totally up to you.
I like the JitterBug, but to be fair I need to do more listening with it, and then without it. I definitely felt that it cooled my Mojo a bit. I have adjusted and accepted the new signature. However my amplifier and speakers are new and good quality. I still take a breath almost every time I use them with the Mojo. I still have the old signature of my previuos amplified speakers I vaguely in my mind.
My new amp and speakers reach lower in bass making the Mojo sound more balanced. Therefor me soon adding a Jitterbug might have been wiser had I adjusted fully to the new amplifier and speakers. My reaction to the jitterbug soothing my Mojo, which I believe was real. Could just me still being taken aback by my amp and speakers. Therefor I really need to do more testing.
However I am sure it has calmed my Mojo a bit and in the right direction. Since the JitterBug is meant to cure slight brightness and very slight fatigue,and better imaging. That's caused by USB power line noise coming from a computer, and entering the DAC analogue stage I think. Then that's what I was sure happened. I love it now.
Yes the Jitterbug is on Amazon. .... However something I think you should do if you have not, is read post 3. You might find it just the place to look over Mojo FAQ.
You should be able to answer your headphone question. However the short answer is, that Mojo can play any headphone. There may be a rare very high impedance headphone that the Mojo might struggle a bit with. However for most headphones, I would strongly discourage a headphone amplifier. Just use the Mojo output for headphones for the freshest signal.
More slam can be added with different headphones or amplifier/speakers. As long as you understand that the Mojo is right then you can try whatever you want with other equipment.
Please do not feel bad tearing yourself away from a bass heavy slamming DAC.
I find the Mojo kicks my music hard so no worries for me. (Try playing INXS - Devil Inside.) It depends on what you pair Mojo with.
