I did a lot of testing here. The problem is related to the phone and antenna power (which goes up when it tries to change cells in areas with bad coverage). It basically made the HA2(SE) impossible for me to use on longer trips (I travel 150km by train almost each day - it cuts out roughly 20 times during the trip, especially under long tunnels with little or no coverage).
I have had several iPhone models (5s, 6 and 7) and both the HA2 and HA2SE. The same problem with all - easy to replicate if you put and stack the phone and HA2 together in a faraday-like container.
If you use a longer cable (just the basic iPhone USB charger one) and keep the devices at least 10-15 cm apart there isn't any issues. Only when they are stacked together (like you usually would). When it cuts out you can also hear the typical "gsm interference noise" in background if you have highly sensitive headphones/iems.
So it's a shielding issue on the HA2 (and SE). If you are travelling a lot I can not recommend the HA2(SE). If you are living in a big city with good coverage - not a problem.
I'm going to give it one last chance before I sell my HA2SE (or tell Oppo to give me a refund) - by putting aluminium foil between the phone and HA-2 when stacking and seeing if that helps. :-/
I love the HA2(SE) - it's form factor and functionality. But I'm close to buying a dacamp or mojo instead because of this... (or just giving up on portable audio and just use the Apple mini-jack converter when travelling).
