GrussGott
- Sep 18, 2016
Yeah, except it seems not that based on Rob's explanation:
[great sound is] complicated and depends upon a number of factors - principally the amount of RF noise injected into the Mojo, and the amount of correlated noise that gets in. It will depend upon the source device as to which sounds best. My preference is optical, as this has the smoothest sound quality and best depth, as it does not suffer from both of the aforementioned problems ...
... all my DAC's up-sample to 2048 times that is at least 16 times more than typical. What does this do? Well its not just about up- sampling but filtering out the RF noise that is present on a digital signal. Its essential to do this, as it gets you closer to the original analogue signal in the ADC (and this is the DAC's job to recover the analogue signal not the digital data). This extensive filtering reduces jitter sensitivity by a factor of 64, and allows the DAC to eliminate noise floor modulation. Now this is a very important problem, as it makes the DAC sound hard and less smooth and is a major problem with DACs - all other DACs have very large noise floor modulation, Mojo has zero measurable noise floor modulation (I have plots at home proving this). This is a major reason why Mojo sounds so smooth and natural.
So I read that as Rob saying he's using beaucoup processing power to get rid of that noise.... all my DAC's up-sample to 2048 times that is at least 16 times more than typical. What does this do? Well its not just about up- sampling but filtering out the RF noise that is present on a digital signal. Its essential to do this, as it gets you closer to the original analogue signal in the ADC (and this is the DAC's job to recover the analogue signal not the digital data). This extensive filtering reduces jitter sensitivity by a factor of 64, and allows the DAC to eliminate noise floor modulation. Now this is a very important problem, as it makes the DAC sound hard and less smooth and is a major problem with DACs - all other DACs have very large noise floor modulation, Mojo has zero measurable noise floor modulation (I have plots at home proving this). This is a major reason why Mojo sounds so smooth and natural.
That noise that's still there.
That no other portable DAC/Amps have.
