adamsmarbles
- Mar 28, 2017
Same issue here. The mojo worked great for about 3 months plugged in 24/7 while using as a desktop dac. Then all of a sudden, it starts shutting down by itself every few days. When I check, the battery is dead. So I take it offline and charge it for 10 hours and plug it back in. Works fine for a few days then it shuts down again. Doesn't seem to be charging anymore while it's in use. I tried multiple 2 amp chargers and usb cables, no change.
Seems like I'm not alone with this problem. I guess I should've listened to my common sense that said don't use a battery powered dac for the desktop but most online info said it would be fine in this situation so I went ahead. Live and learn.
Thanks for continuing the talk about 24/7 Dac use, battery etc
Its very annoying being told by Chord that Mojo is good to be used 24/7 and having people who know about the battery more say, it will die and being on the 2nd mojo myself having it happen again.
P.S
1) Bleeding: im still trying to bleed it of juice an hour after it turns off for low battery, it still got juice left to turn on, so im here like flicking its switch constantly..
2) Im going to try disconnecting the power cable every few hours for 10 seconds and plugging it back in, to try and trigger it to recharge, i believe it was suggested somewhere.
