Ike1985
- Oct 22, 2014
The meenova off cable made no difference with regard to getting Mojo to work with apps other than UAPP. Confirmed: not a cable issue.
I started a thread about this, but didn't get any real answers: I'm looking for a more aggressive DAC than the Mojo that costs $500 or less. The Modi Multibit is what I'd go for if I can't find a better alternative. Both MMB units I owned made mysterious crackling/popping noises that the manufacturer could not replicate. Back then I only used USB, but perhaps with TOSLINK, it wouldn't do that anymore. I think the Mojo is more refined, but its smoothness is becoming a problem for me with more energetic music. The MMB is affordable enough that I could compare it directly to the Mojo without having to get rid of anything beforehand. (I used to have a 2Qute, MMB, and Fulla 2 at the same time.) Just wanted to check here to see if anyone knew of anything else I should check out.
If I use another DAC, I'd just use a passive preamp for the volume control. I have a Schiit SYS, but it makes scratching noises, so I'd like to try the JDS Labs OL Switcher.
Would you recommend the black label over the mojo?
You would be better off getting aggressive speakers to be honest, even though dacs can do incredible things to part of the sound its only a very small portion of the overall final sound quality.
I'm very happy with the speakers I got today. I didn't mean overly aggressive.
I think the Schiit signature sound is aggressive so have you tried Bifrost multibit i think that might be around $500? you seemed to like the modi so i thought of that.
Also when you have many different dacs all lined up side by side and do level matched comparisons the differences are wayyyy smaller than you believe compared going from one to another with breaks in between.
i dont demo i buy. it was the Modi 1, Modi Multibt and Vallhalla 2.Not sure which Schiit you demoed, but Bifrost Multibit is definitely not aggressive nor bright at least compared to some Sabre DACs. It's pretty neutral overall and if the track recalls for aggression, both Mojo and Schiit delivers them without lacking energy. Mojo definitely is smoother though, but on my speakers, I prefer the less polite Schiit since it makes the speakers more alive sounding than Mojo.
Can you please educate me on how the signal processing 'will occur' once I have chord mojo driving HDVD800. As in my mind I see, Laptop output --->> Chromecast audio (does DAC processing occur here?)----> Chord Mojo (does Dac processing occur here?)----> HDVD800 (using the 3.55 to RCA from mojo, does DAC processing occur here?)-->HD800s. In my mind, since the chromecast is the first link in the chain, the signal is already manipulated before it reaches the amplifier thru mojo/hdvd800.
Thank you, I've ordered the RCA cable. Can you please educate me on how the signal processing 'will occur' once I have chord mojo driving HDVD800. As in my mind I see, Laptop output --->> Chromecast audio (does DAC processing occur here?)----> Chord Mojo (does Dac processing occur here?)----> HDVD800 (using the 3.55 to RCA from mojo, does DAC processing occur here?)-->HD800s. In my mind, since the chromecast is the first link in the chain, the signal is already manipulated before it reaches the amplifier thru mojo/hdvd800. Thank you
