Chord just redesigned/updated their website, definitely an improvement:
http://www.chordelectronics.co.uk
I need to play around with it more, because I don't use line-out much.
What I'm saying is that yes, the first time I used the line-out preset (hold balls during power up) it went to the 3V setting. I turned the level down to ~2V because my amp can't handle the 3V.
Then when I turned on normal mode (no ball holding) it went back to the 2V (and I almost blew my ears off). Now when I went back to line-out mode, it also reverted back to the 2V level, not 3V.
Again, I need to try this again, because maybe the colours confused me... Oh Mojo, why the colours... what's wrong with numbers? If he wanted to have digital control without a potentiometer, why not just a tiny display with numbers.
OK, so I was wrong...
Pushing both balls during power up will put the device in 3V line out mode every time. It's just really hard to distinguish the colours between 1.9V (=4 clicks down) and 3V.
What I was right about and what is potentially dangerous. IF you turn on the device in line-out mode, change the level to e.g. 1.9V, the next time you turn on the device in normal mode, it will be set to 1.9V!!
Black Friday coming up.... Any news on thr SD module.... My goodness.... It will be fantastic and I would think.. It will be the best transport
Do you guys think it (SD module) feed mojo via USB or coax? Or opt?
Next year sounds worseThere was a post a few hours ago, that chord estimate next summer.
Very True... Now every time i use 4 clicks down from line level.. i have to keep this in mind.. so that next time i turn on the Mojo. i have to lower the volume else i will end up frying my ears or my earbuds !
Yup... I had a blast of music played back to me at 2V through my super sensitive Shures... Not nice... Luckily I pressed play, thought about what was gonna happen, pressed pause again immediately... but a 1 second blast still made it through.
Thanks for your help..
mine is 8010 model not the G versions....
i will do some testing.....this weekend with these settings
Genelec 8010 deliver 100dBSPL at 1 meter with -6dBu input level( 0.38Vrms ).
If Mojo is directly feeding them, I would suggest to set it around 20dB/clicks below the 3Vrms.
Rgds.
Enjoy
I had asked this same questions in Genelec official forum(10 months back) and the [COLOR=222222]representative [/COLOR]said 3V rms is no issue for F One SUB and 8010..
But anyways i will for sure do some testing this weekend
I had asked this same questions in Genelec official forum(10 months back) and the representative said 3V rms is no issue for F One SUB and 8010..
Fine. No use to worry then .
Mojo's output level has no sweet spots per se. The only thing you have to take care is to be under clipping voltage. Since active speakers present an impedance of 10kOhms, Mojo is not clipping even at max output.
Regarding your monitors, they have external 10 dB attenuator switch added apparently with sufficient internal attenuation stages.
Enjoy your testing & listening .
Thanks for your such useful tech info.. thank you.
Fyi.. i know nothing abt music and all tech specs you mentioned .. i just bought Mojo and Genelecs for causal listening .. I am so lucky and glad i found Headfi 1 year back !
How many of you like the Chord Mojo case. Is the case worth the 100 bucks and does it seem robust?
Can I charge the mojo with an apple iPad wall charger?
mojo has got me "lusting" for a dave, its a strong gateway drug.
