What if they are also working on a Mojo Mk II with Bluetooth and SD support built in?
Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
Then mine would be going back within the return period!What if they are also working on a Mojo Mk II with Bluetooth and SD support built in?
GreenBow
- Feb 6, 2015
@Mython
Thank you for the What Hi-Fi Awards post on the Chord DACs. It made me think to go off and buy the Awards copy.
I have last years Awards copy and I noted the DAC categories have changed. Last year:
The best DAC under £400 was the Oppo HA-2
Then best £400-£800 was Chord Mojo (and Product of the Year).
Then £800-£1200 Chord 2Qute
Then £1200+ Chord Hugo
I wondered a bit why they changed the categories about. Now (as you informed us,) the Mojo sits in best DAC under £500.
Now as you said, it's:
[Dragonfly Black Under £100
Dragonfly Red £100+]
Mojo under £500
2Qute £500-£1000
Hugo £1000+
Mojo under £500
2Qute £500-£1000
Hugo £1000+
- Dec 24, 2015
Maybe brexit is affecting exchange rates, think euros are edging closer to pounds
I just got the Mojo and leather case from Amazon.co.uk today, for about $150 less than what I would have paid at Amazon.com. It arrived in 3 days too! I am absolutely ecstatic!
NaiveSound
- Nov 8, 2015
I wish I had a cheap case
mcluxun
- Jul 29, 2005
Got my mojo today. I'm wondering if anyone has ran into a compatible issue with amps.
I have an amp works perfect with other dac and cellphones, but malfunctions with Mojo.
GRUMPYOLDGUY
- Aug 19, 2016
Does the headphone out port you're connecting it to work with your headphones? If so, the Mojo is not at fault.
The other thing to check is to be sure your output level on the Mojo isn't overdriving your amp. You could potentially damage the components in your amp if you overdrive it.
x RELIC x
This is most likely the issue as the Mojo's line level volume setting is 3Vrms by default in the line-out setting. Try lowering the volume by 4 clicks to get 1.9Vrms to your amp. If it still clips then lower further.
why would you want to degrade the sound quality of mojo?
3ggerhappy
- Oct 1, 2015
Noob question. For how exactly would you know the supported line level accepted by a particular amp, is there a specific info in the specsheet to look into? For example I have the schiit jotunheim and want to use the mojo as DAC how would you know it is not overpwering it?
GRUMPYOLDGUY
- Aug 19, 2016
It's generally a good idea to go with the standard. -10dBV is what consumer audio equipment is typically designed to.
This is about 20dB (clicks) down from the preset, which is double red (I think, just below double yellow). You can move up or down from there to your liking.
3ggerhappy
- Oct 1, 2015
Thanks for the info I will try it out later when I get home.
Also another question, I have read on the 3rd page that the color of the balls would be light blue on line out mode(holding the 2 balls on powerup) but mine would lit up with a light purple color in this mode, unless im color blind I think there is something wrong with my unit? I have the mojo for a year now and just started using this line out feature so help.
x RELIC x
As far as I know most amps are designed to handle 2Vrms as set as the standard for CD player output. The best way to be sure is to contact the manufacturer of the amp and ask what Vrms Input it can handle.
x RELIC x
There wouldn't be a different setting from unit to unit. I think it's just a descrepancy between colour description. For example, others have described the colours in the lower level as brown when I'd say they are red/orange.
Mine are violet when set to line output level.
- Dec 30, 2013
Just got my own MOJO. Thanks to x RELIC x for introducing me during the MOJO review tour earlier this year. I said in my review that I saw a Mojo in my future, and today's the day!
Thanks, my friend!!!
Total: 6 (members: 0, guests: 6)
