warrior1975
- Dec 5, 2013
And the sound of course.
All I have is me and my Mojo....
My wife made be dump my stereo amplifier and speakers, DVD player, and desktop set up (Schiit Bifrost Multibit, Vali, LH Labs Geek Pulse Sfi) in a closet...
She hates cables more than she loves me.
would it be better to lace the whole cable with them instead of 1? LolOne thing you can try is applying a small ferrite choke to your interconnect cable, between your transport and Mojo:
http://www.ebay.co.uk/itm/Clip-On-EMI-RFI-Noise-Ferrite-Beads-Split-Core-Choke-Clip-Filter-5MM-USB-Cable-/281961820637
(make sure you choose one with a core diameter suited to the thickness of your cable) - you might already have one you can borrow from an old USB cable
Obviously, ferrite chokes are not relevant if you use an optical cable! :wink_face:
Also guys, with this mojo, is there an app I can use it with which will remember my downloaded offline content on Tidal? If I go direct through Tidal then mojo will be using my phones DAC or being upsampled or something? When I use UAPP it uses the mojo in bit perfect from my understanding.
It would be cool to listen to my Tidal playlist instead of searching individually and using data
The wife has to go. Sorry but that's your only solution.
Until a month later when she starts-up again, and we go through the same routine pretending it is the first time.
Been through four cycles.
Every month she asks, "why do you need all those cables?"
"Here, let me explain, this one is for..., and that one..." As if she really wanted to know.
So, I remove them all, and don't speak to her for three-weeks until she acquiesces and I get my toys back.
"I never asked you to remove the cables, I just wanted to know what they were all for and why you cannot keep them neatly."
"Really? You wanted to be educated on the purpose of each cable? Yeah, sure.
Help me place the cables back, show me how it can be done neatly."
I end up recovering my toys when she witnesses most of my life's joy has been eviscerated from my soul.
I love my Mojo, more than she hates cables.
A single Bluetooth box is adequate for her music listening, she would never listen with headphones.
