- Aug 4, 2014
As a proud, but encumbered owner of a Mojo triple-stack, I've made it my duty to come here every two months to ask if there have been any news on the SD card reader module?
I don't know if this is the best place to ask this query. But I am certain that my fellow Mojo users would be able to help me.
While I don't have any plans of buying any audio gear in the foreseeable future, I am thinking of saving up for a desktop DAC to pair with my desktop amp, a Lake People G109-A. Currently, when listening to my mid-fi HPs (Sennheiser HD600 and HifiMan HE-400i), I used my Mojo as a line-out DAC to feed the LP G109-A.
Is the Mojo still better than, say, a Schiit Bifrost Multibit (Bimby) DAC or the Lake People RS 06 DAC (which is somewhat similar to the Violectric V800)? That is, am I better off sticking with the Mojo than getting the Schiit or LP/Violectrick desktop amps? As much as I want to "upgrade" to a Hugo, its price is just too prohibitively expensive for me.
Thanks in advance!
IMO, currently owning both DAC, Bifrost Multibit is noticeably ahead of Mojo in depth and holographic imaging (Bimby presents a concert hall soundstage while Mojo closely presents a studio room). IMO, both are equal in detail retrieval and instrument layering, but to me Bifrost Multibit sounds more natural to my AKG K712 headphones while Mojo is slightly brighter/harsher sounding. To some, both are just side grades to Mojo. IMO, if you need a decisive blow against the Mojo, you have to upgrade to Gungnir Multibit.
Best to buy TWO Mojos. Gave one charging while using the other.
@theveterans
Thank you very much for the comparo kabayan!
@x RELIC x
Unfortunately, we don't have a Schiit distributor here in Manila, only for Violectric amps (I got my Lake People amp from that same distributor, but that was a one-off opportunity as they really focus on Violectric products). Hence, getting the Violectric/Lake People DAC locally would be much more feasible than getting a Bimby.
My thinking behind getting a dedicated desktop DAC is to preserve my Mojo's battery life. Given that the Philippines is a tropical country and I don't have air-conditioning in my room, I fear that subjecting my Mojo to continued use while plugged in the mains/USB hub will drastically shorten its battery lifespan.
Nonetheless, thanks for the prompt feedback!![]()
Best to buy TWO Mojos. Have one charging while using the other.
You mean charge the Mojo while using the Mojo ? So in MY CASE when I go to three different schools to coach which takes multiple trains, buses and a taxi which usually takes 3 hours a day of traveling. I should take two phones (one to use as a phone the other to use with the mojo) the Mojo and a charger on my daily travel in Hong Kong? Sorry this boggles your mind. I read its BEST not to use the Mojo while CHARGING the Mojo. In Hong Kong its 98% humidity and reaching close to 40°.I don't understand why you would not just spend $50 a a rechargeable power unit that holds enough power to run the Mojo for a few days. I've seen people say this a few times in this thread and it just boggles my mind that people are so unaware of inexpensive powerpacks.
