masterpfa
- Dec 30, 2014
Too bad it's so much harder to find short micro USB to usb-c compared to the lightning connectors.
Almost impossible, I have given up that search for the time being.
The usb connexion is OK between Spotify and Ibasso, why not with Mojo ? I can listen music from Spotify via otg connexion, so why not with Mojo ?
Do you mean you can only stream Tidal through UAPP if you care about Android's native resampling? If I don't care about Android's native resampling, I can stream straight from Tidal to Mojo correct?
Oh, i see now.
- How i use tidal through UAPP? have some step-by-step to use it?
- Another thing... do you know if can DOWNLOAD TIDAL music, and get the music to save on the SD to listen on UAPP or ONKYO?
Do you know some magic that I don't?
I can't get tidal to work natively on my g3 or v10
Yes Tidal works natively on both Android and iOS
Only difference is the Android upsampling
Press on Orange icon in the bottom right
select Tidal
You can only stream via UAPP to access stored offline music you will need to use the app
Anyone prefers MOJO over HUGO???
Greater in which area?Great product but Hugo greater!
mainly brighter and less bass?I just wrote in Hugo thread, but to repeat, in clarity. And on a personal note, I appreciate the lack of warmth added. Must be pointed out though that these are slight differences not major.
Happily I'm not cost-constrained.
Nikon make fantastic cameras - but they're targeted at a completely different set of use cases than Leica's mainstay cameras (the M system). If you want a rangefinder, or easy access to, and use of, Leica's superlative lenses, then Nikon does you no good at any price.
And, if you care about size/weight when traveling (as I do - where every cubic inch and oz counts), then the Leica M system beats pretty much everything ... except on price.
