warrior1975
- Dec 5, 2013
utdeep-Which cable are you referring to?
Don't forget that the signal interference depends on what type of signal you're pulling in (2, 3 or 4G) so if you're in a good signal area you won't have any problem at all, fringe area, or one with an older 2G signal, the RFI will be all around the mojo.
I'm enjoying my rekindling love of mojo, on my long arduous journey, my little triple stack is putting a smile on my face
So which driver are you supposed to use if you are using Windows 8.1? I can't find any specification about that, only that there is a driver for Windows and Windows 7?...
I think "Windows" means Windows 8 or newer and "Windows 7" refers to just Windows 7. At least that's how I interpreted it and I haven't had a problem on Windows 10.
Is there any way to charge and play from your iPhone at the same time with using the mojo?
Yup works on my iPhone!
I'm using the new USB 3 CCK with my iPhone and Mojo and can use the Mojo and charge the iPhone at the same time.
I only get RF on occasion and only when they are stacked one on the other.
Putting it on airplane mode takes care of the problem.
Also, when I listen to them flat on a desk, next to each other, there is no RF.
On a certain walk, under power lines, there is one spot, always, which gives a nasty RF. As I approach it, I know its the same spot each time. I wonder if some material between the iPhone and the Mojo might help?
Even on my lap, if side by side, gets no RF; only in stack. I also have an extra cable with me that is 2' long and works nicely for just setting them down next to me. I have tried the longer cable, with phone and mojo in opposite pockets and this works too. Strangely enough, there are times, on the treadmill, where they are stacked and I get no RF. I prefer to get no calls so I don't mind the Airplane mode.
Aha. Do you run mojo only via phone? I would recommend, as you are seriously bitten by the Mojo-bug, to looking into a cheapish player to use as a transport. Even an older, superceded model would be a great option, digital out is, for the most part, still digital out, even if it's in last year's colours and stripes, so to speak! I always find the whole thing about using a phone to listen to music with is a bit of a non-sequitur, as the distractions are too many and the interface is so poor and pretty buggy at the best of times.
It's also so nice to have the buttons accessible on a dedicated player which can be pressed through shirt pockets, etc.
I think i remember I noticed you mentioned you are running T1.2's with your mojo? I have the T1's original version. Got them a few months back at a bargain price, and I can't fault them. They are just amazing with the mojo. So many things are "right" when I listen. One of the most noticeable things is how the music flows and swells in dynamics in a natural, effortless way. And the micro-detail on tap is incredible. I would dearly like to get some IEM's which can duplicate that!! I have the K3003's from AKG but they just sound a little stressed and lacking by comparison. Very good in isolation, but compared to the T1's... hmmm. How do your's fare with the Mojo?
