Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Apr 22, 2016 at 1:10 AM Post #16,471 of 42,916
Quote:Originally Posted by noobandroid
moon audio cables are expensive when buying for overseas shipping, i used to consider them but the shipping cost is "wow" :fearful:
I would say moon audio overseas shipping is extortionate i checked for the form fit otg cable $85 shipping to the UK was $48 absolutly rediculous.
Apr 22, 2016 at 1:19 AM Post #16,472 of 42,916
It's because they lose sales due to shipping costs, so they have to put shipping costs up.
Apr 22, 2016 at 2:09 AM Post #16,473 of 42,916
I ordered my TRRS 4-pole coax from Custom Cable UK. Shipping cost me 5 sterling pounds
Apr 22, 2016 at 3:05 AM Post #16,475 of 42,916
just joined the Mojo club.
Does anyone know where I can get a short optical cable (3.5-toslink, 15-20cm), to connect my AK120ii to Mojo, in Europe?
thanks for your help.
Sysconcept ships to Europe.
http://www.sysconcept.ca/
http://www.sysconcept.ca/product_info.php?products_id=349
Apr 22, 2016 at 3:29 AM Post #16,477 of 42,916
And their cables are wonderful.
Easily and reliably handling 24/192 content from even the original AK120.
I bought the 2.2mm cable originally.  It's FAR smaller than it looks in the pictures on their site and, if I was doing it again, while I've had NO issues, I'd buy the 5mm version since it'll still be incredibly compact and would be much harder to accidentally damage in use (especially when traveling).
Apr 22, 2016 at 3:46 AM Post #16,479 of 42,916
  thanks, but they're way too short.
They'll build you any cable you want.
Just have to put the specs you want in your order, or contact them prior to placing an order to sort out what you want.
They are INCREDIBLY responsive.
Even for my custom order I had a response in minutes and my order still shipped the same day ... and I ordered well beyond midday.
Apr 22, 2016 at 3:49 AM Post #16,480 of 42,916
There are other options on the site that allows you to specify the length. You don't have to choose the Super short right angle option. Just look around there and I'm sure you'll be able to find something you need. If not contact them with your exact requirements and they will make it for you.
Here are some other links from the site that may help understand what else they can do for you:
http://www.sysconcept.ca/product_info.php?products_id=219
http://www.sys-concept.com/U-toslink_miniplug.html
Apr 22, 2016 at 3:49 AM Post #16,481 of 42,916
oh, thanks!! did not know that.
will give them a shout for sure.
Apr 22, 2016 at 3:54 AM Post #16,482 of 42,916
Indeed and then to get hit by Customs and VAT in the UK.
I personally no longer use Moon Audio for this reason, my wallet protests too much.
They can make a cable to any length you require, something like this maybe what you need.
