jmills8
Previously known as bmiamihk, jmills2
Mojo - Phone - Flac - IEM. Fully charged blue light, did not turn off Mojo. Blue light lasted 1hour 45 minutes. Volume one before White light.
Thanks for replying. I listen to 16bit flac files and stream spodify most of the time on my phone, which one will give me a more noticeable improvement? ( upgrading from a fiio x5ii )
I really dont think anything is faulty , I think thats the battery life.Under 2 hours fully charged? Faulty?
Both improves sound quality over x5ii. Hugo and Mojo are two differently tuned DAC. Give a listen for both & decide. Of course there are other aspects, i.e. Size, price.
Anybody else notice this:
I use my Mojo permanently close-coupled to a Z5 Compact with 200GB microSD as my music source (not using the phone for anything else) to hold a range of mp3/flac/dsd.
As most know, the Mojo is affected by electrical interference from phones aerials especially if close-coupled, with recommendation to put the phone in "Flight-mode" which then stops it being used for streaming media (Spotify/Tidal). I have found that over wifi only there is no interference 99% of time but with 4G enabled the interference is constant. I then tried turning 4G off just forcing 3G and interference greatly reduced, similar to WiFi. Anybody else confirm this? I'm only using a cheap short right-angled OTG cable as seen in photos.
Thanks for the reply. How are you using your Mojo, dap, pc, phone? What sort of headphone or iem ? EQ? Volume ?2 hours, which is just 25% of the claimed battery life sounds faulty to me. Mine lasted more than 8 hours.
Recently acquired a Mojo and let's just say it's lived up to the hype. So much I'm thinking of just keeping it and replacing my current rig's DAC.
Any issues using the MOJO primarily as a desktop DAC??? I know each time you power it up you need to set it to line level.
Also I'll mostly be using my DX80 to output via COAX to it. Will any 3.5mm to 3.5mm cable work or should I get something more specific?
Hello guys, I'm stuck between getting a chord mojo or a Fiio X7 itself. How do they compare in term of sound quality?
I think i'm getting about 5-6hrs max with mine. All i've been using with it is iems and volume mostly at red-yellow, blue when i'm on full basshead mode. so it's not like i'm using a lot of the power.
I'm gonna go full charge to full drain and mark the time after each use to find out if I need to send this thing in.
