I do not buy this all. You need to bear in mind several facts:
1. The battery is capable of delivering 3A of current, and has very low impedance.
2. Mojo amplifier has a very high power supply rejection ratio.
3. The output is pure class A at 5v RMS into 300 ohm.
4. Reducing the output load only starts to increase distortion with 33 ohms - at this level it is very much lower than other headphone amps. The HD25 is a very easy 70 ohms.
5. Mojo is designed to drive loudspeakers. You will be amazed hearing it fill the room with beautiful sound using efficient 8 ohm horn loudspeakers.
Some people like the sound of more distortion - 2nd harmonic fattens the sound making everything sound phat, soft and rounded. But its not natural, nor do I find it musical, as everything sounds phat. I want soft sounds to sound soft, and sharp sounds to sound sharp - not everything to have a soft sheen on things all the time.
I can give you another example. I just had an email today from a very experienced dealer that asked me this question:
"Chord Mojo should have single amplification which drive to both headphone output, but if I'm using any headphones (HD800 for example, very heavy to drive) to put on headphone output 1 and I connect another headphone to headphone output 2 (Beyer T1 for example), I hear no differences on sound quality. Normally if one amplification section used to drive 2 headphones output, then once we connect the second headphone will make overall sound quality degradation (as the case of Beyerdynamic A20 amp, Grace Design M903, etc). What is the logical explanation of this? As it seems Mojo has 2 separate amplification sections which drive independently for each headphone output."
Of course Mojo does not have two amplification stages. It can drive two headphones with ease because it has exceptional low output impedance, and it has exceptional current linearity. So loading it with more headphones has no effect, unlike other headphone amplifiers.
Indeed, when I initially started designing Hugo I was shocked how poor from a measurement point of view headphone amps were. Poor output impedance, huge levels of distortion, and poor current linearity seem to be typical. And these things matter, if your goal is transparency and musicality.
Rob
