x RELIC x
I was advised it would be safe. Didn't realize it would run the risk of damaging anything...Would a female trrs to a male trs 3.5 adapter work?
I keep forgetting which is not allowed: I thought plugging unbalanced trs jack to a balanced trrs was the fatal one but not the other way around..
Thanks for the quick reply btw
Driving SE headphones from a balanced output is bad. Driving balanced headphones from a SE output, with the appropriate adaptor, is fine. That said, without the adaptor to run TRRS to a TRS output there may be risks given there is no common ground on a TRRS balanced plug. TRRS will be something like L+, R+, L-, R- (depending on the manufacturer) and TRS will be L+, R-, common Ground.
Edit: Be aware that there really is no standard for TRRS connections. Astell & Kern uses R-, R+, L+, L- for their 2.5mm balanced output. You need to be aware of what configuration your TRRS plug has for the adaptor to work properly.
