ajay555
- Oct 23, 2014
I noticed that the new case Hugo has the USB connectors rotated 180 degrees. Not sure what the impact is.
Chord have been producing "upside down" USB Hugo's for some months. They are new USB connectors, which have solderable pins. This means the connector is soldered at the top of the PCB and the bottom of the PCB via the connector pins, making it impossible to break the USB connector from the PCB. This mod had no difference to SQ.
Rob
on a side note are you using Hugo as the Dac instead of the AKurate's internal DAC? Are you connecting to spdif? Have you compared it with a mac and a good USB cable?
thanks
hi m8 how did you manage 2 fit the super nova 7 into the Hugo?I did some research and pulled the trigger on a WiredWorld Super Nova 7, 0.5m Toslink cable. Anyone else have one? I was not prepared for this.
I’ve always wondered if my multi-stage routed home wireless LAN, with NAS, wireless LED lighting, Airplay, etc… - just so much interference flying through the air - had an effect despite my preventive measures.
Just running Red Book, everything is (so much more) tight and controlled, rich, open, dymnamic, transparent, beautiful. The bass is so taught it almost is crunchy. In a very good way. Mids ooze endlessly, and the tranparency up top is remarkable. I can hear that there was distortion that is just gone now. This is the best I’ve ever heard Hugo. That includes of any DSD, or running hi-res USB through AP2+PurePower with a Synergistic Research USB, or Heimdall, or Cardas, or anything. Enrapturing, expansive
Sorry mate, just to clarify,
All these amazing improvements are compared to a standard toslink cable? or a USB connection? What were you using before?
Thanks!
Very cool looking setup sir. I like the precise quality of your interconnect cables. Now all you need is some giant Audeze hp's to walk around with your portable tubes. Do you know anybody whose got some good champagne?While waiting for my Eddie Curent 445 desktop tube headphone amp to arrive, I just received his (very) little brother: a TUR-06
very nice complement to the HUGO ! Warmer sound but still precise...
So, now, "on the go" or at home, I will be "all tube"
YES: AK100 > HUGO > TUR-06 tube amp
Just need to do some tube rolling now to find the perfect match...
