woodcans
- Aug 1, 2004
The Chord Hugo should only go to line level if you press and hold the crossfade button when you power the unit up. If you are not doing this then there could be something wrong with your unit unfortunately.
Thanks Phil. Mine powers up to green, which is tympanic membrane piercingly loud with iems (which is why I assumed mistakenly green was max or near max volume). With full size cans it's not an issue. Full/line out color seems to be light purple, which seems to work correctly.
