May 26, 2014 at 9:52 PM Post #3,526 of 15,723
Last nite, I tried comparing DSD in DoP format and PCM in 24/88 FLAC format for an SACD rip.... I have to confess not a huge difference between the two
May 26, 2014 at 10:14 PM Post #3,527 of 15,723
This is not what I understand. I think it was told that they do not see the demand to warrant investing in such product. They have other good things in their pipeline anyway.
There is no overkill in audiophile, its cool to use AK240 as a transpprt.
And it does make a difference. Many believe all transport sound the same. My personal personal experience say otherwise.
May 26, 2014 at 10:18 PM Post #3,528 of 15,723
I agree. I hear difference from DX50 coaxial vs HM-901 coaxial. All these little things in our hobby (cable, power, etc etc) contribute subtle differences in sonic...
May 26, 2014 at 11:05 PM Post #3,533 of 15,723
I have heard very appreciable differences in transports.
My ideal for the Hugo would be a unit with USB out so that DSD could be supplied natively. I would also like several SD cards slots so you could carry 256GB times the number of slots, hopefully four. I'd also want great front end on iPhone, iPad, or Android with control over bluetoooth -- would be awesome because you don't really need to carry around a second display and you don't want to change network just to hear some music. A single charger for both would also be great.
I hope Chord is listening. Meridian could also downscale their Sooloos and it would be amazing.
May 26, 2014 at 11:23 PM Post #3,534 of 15,723
controlling the player from cellphone would be great!
May 27, 2014 at 1:29 AM Post #3,535 of 15,723
The guideline also stay: "the owner of the Chord Hugo and Audio-gd Master-7 is due to post a comparison as soon as reasonably possible"
:-D
A comparison of the Hugo to the master 7 I would very much want to read as well. As per a headfi friend the hugo is really special.
Al
Using my Digital Interface to feed both, the Master 7 via I2S (using an internal cable through the top of the M7) and the Hugo via coax, I could A/B them easily, volume matched, through the Studio Six. I felt that the Hugo was a bit smoother/cleaner/clearer sounding than the Master 7. I think that to get the same with the M7 I'd probably need to use an OR5. What I sometimes want in a DAC was one with the clarity of the M7 but the smoothness of the NOS1704, so I've long been pondering getting an OR5 to remove that last touch of hardness. The Hugo is that IMO. The Master 7 is for me, everything I wanted in a DAC, without having to compromise. The Hugo is that, but a bit more so still.
  I'd like to see a shootout of AK240 vs X5 vs DX50/90 vs HM901 vs .... as transports feeding the Hugo...
Anything that uses a TRS to RCA adaptor for a transport, in my experience, isn't going to be so great. Mind you, I felt there was more of a loss using an iPhone or iPad vs. USB from my MacBook Air with the Algorithm Solo than there is with the Hugo (with my iPad and CCK into low-res USB vs. my Air via high-res USB).
May 27, 2014 at 5:52 AM Post #3,537 of 15,723
Currawong can you explain the i2s input method used for the M7. ? I use the offramp or USB only. With the offramp and HDMI input from dac ladder it bests the USB .
Also do have the latest USB flash on the USB card and drivers in the CPU ?
The Hugo seems to get a high praise I am interested where it sits compared to the M7 sound .
Al
May 27, 2014 at 2:09 PM Post #3,540 of 15,723
Amos, this does me in... finally broke down and get myself one!! I blame you for another hole in my porous wallet!
Btw, any optical cable that can carry higher than 24/96 besides the sysconcept one? I can't get my stock optical cable to work with 24/176 or 24/192 though I thought I saw someone posting stock optical cable works...
