Anyone know which is generally regarded as being the better input on the QBD 76, optical or coax?
BNC 75ohm Coax if signal is from a good quality CD Transporter. Optical from a Mac Book Pro via phono jack. USB if from a standard PC.
Thanks. Got a good deal on the old bluetooth model. I'll be hooking up a Cyrus CD transport and an Auralic Aries.BNC 75ohm Coax if signal is from a good quality CD Transporter. Optical from a Mac Book Pro via phono jack. USB if from a standard PC.
hi m8,I've been using a using a cyrus se2 transport with a psx-r with the qbd76.ive tried 2 cables with it,a supernova 7 optical cable and a chord anthem digital tuned aray coax.I ended up using the supernova 7 optical cable to my ears it sounded slightly better but it was close. I've just had a good deal on a chord blu transport and am experimenting cables with it.Thanks. Got a good deal on the old bluetooth model. I'll be hooking up a Cyrus CD transport and an Auralic Aries.
Im using twin BNC Tellurium Q Black Waveform coaxial cable from my Blu Transporter to my QBD76 DAC's to obtain 176kHz sampling.
Atlas make rca-bnc adapters,their about £18 for 2 and their the best I've ever used;got them from hifi lounge by post.ive also tried AES out with a van dan hul cable called the second,it's a carbon cable and sounds great,but will be trying some more AES cables out in the next few weeks.Are you using RCA-BNC adapters and if so which ones?
I've also just realised the Aries has an AES output. Anyone used that?
Yes it does remember all your settings when you turn it off at the mains.One more question chaps. Does it remember the input and buffer settings when it's switched off at the mains? Thanks.
I now have it set up and sounding lovely. I have a minor issue however, my Cyrus Streamer is connected via coax and the QBD gives a lock error for anything above 96KHz. These files work fine with my Cyrus DAC and Chord Hugo. I've played the same files over bluetooth on the QBD without issue. It's not cable related is it? Hopefully this is just an incompatibility quirk. Like I mentioned earlier I have an Aries coming soon.
you can have your QBD 76 upgraded by chord 2 support usb 192 for £680.Damn. I can't believe I didn't know that. USB doesn't support 192 either does it?
I guess if I want to keep it I'll have to do some downsampling.
