Never got a chance. Going by what I read in the thread about it, the USB input and oversampling filters seem to be not so advanced compared to other options out there, but I'm not sure if that has changed since I last read about it.
Chord Hugo 2 desktop alternative
- Thread starter doraymon
I have a Mytek Brooklyn. It's fully featured and is a great DAC that will drive headphones and has a phono section for analog. It comes with a half rack form factor. I only use mine as a DAC. The only DAC I would consider is a Dave to replace it.
Agree, I am also happy with Brooklyn. It is good all arounder everything usable, good dac, good preamp I use it with active speaker, also good headphone amp good synergy with planars like LCDX I guess with Ether Flow will be similar (not good with IEM though it hiss).
When I had at home Hugo 1 I did not like it as regards usings also not good preamp. Brooklyn is better in my opinion in everything.
Do not know how Hugo 2 though, probably whole new piece.
Doraymon dacs you mentioned probably all adult dac, maybe you should look more on sound character what will suit the most to your system. For example when I tried Stax 009 with KGSSHV my friend had 2 dacs to comparison Yggdrasil and Audio Note V and for that system was better Audio Note becouse it added more weight visceral feel to sound simply better synergy and vica versa I with some different headphone darker for example might be better option Yggy etc...
dmance
Member of the Trade: AudioWise Inc
I just posted my review of Hugo2 as a Desktop DAC. https://www.head-fi.org/showcase/chord-hugo-2.22209/reviews#review-19198
SearchOfSub
- Aug 28, 2013
I am a Hugo owner looking for possible upgrades.
I like the idea of moving to Hugo 2 but I use it as a desktop DAC and its layout just kills me!
With my actual Hugo I have cables everywhere, crossing one another and together crossing my headphone amp connections.
Can anyone suggest a few alternatives to stay in the Hugo 2 league (SQ wise) but with a more desktop friendly solution?
Budget around $2,500.
My setup:
Mac Mini as Roon Server --> sMS-200 (network player) --> tX-USBultra (USB decrapifier) --> Hugo --> Cavalli Liquid Carbon 2.0 --> Ether C Flow.
Thanks!
List of suggestions:
Denafrips Pontus
Schiit Yggdrasil
PS Audio Directstream Junior
Holo Audio Spring R2R DAC
Auralic Vega?
doraymon
Yes I considered it but apparently it's not competitive in terms of price / sound quality with the other DACs mentionedAuralic Vega?
Greeni
- Sep 15, 2008
Was considering Schiit Gungnir multibit or schiit Yggdrasil, but then read of review of Chord Hugo 2 by John Darko of Digital Audio Review, who apparently ranked Chord Hugo 2 quite a class or two above the Schiit Gungnir, which intrigue me as I used to think of the Chord Hugo 2 as some sort of portable device rather than full fledge audio component. Of interest to me is that apparently John also found the Chord Hugo 2 to be a decent preamp, which is contrary to my regrettably limited experience that preamp falling short with adequate power supply are inevitably compromised, and it does looks like you will have a hard time squeezing a decent power supply into the small chassis of the Chord Hugo 2. I was tempted by John’s review to consider take the Chord Hugo 2 over the Schiit Gungnir, as after accounting for the extra cost for a pre-amp, power cords, interconnects, etc., the Chord Hugo 2 as an overall package actually cost less than Schiit Gungnir multibit and all those stuff added together. Appreciate some opinion on how does the stack up against the Schiit Gungnir multibit or schiit Yggdrasil.
IMO if you like Chord sound, you might not like Schiit sound since to me the transients "timing" feels off with the Schiit compared to Chord. I'd stick to 2Qute for your desktop and save more money for something else.
Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
Chord DAC/amps are also digital preamps. The amplification is in the DAC's analog output stage and designed to be as transparent as possible, so in some cases it's akin to listening to the DAC directly. The only thing it does as a preamp is digitally adjust the voltage output, so it's giving you just as much accuracy as a passive preamp, with more precise control.
I love the 2Qute. But the tech in the Hugo 2 is much more advanced. The 2Qute successor with Hugo 2 tech should come soon enough.
Arniesb
- Dec 12, 2013
2qute successor cant come soon enough. Cant wait. Hopefully they will not wait 2018 CES or something and release it faster before Christmas.Chord DAC/amps are also digital preamps. The amplification is in the DAC's analog output stage and designed to be as transparent as possible, so in some cases it's akin to listening to the DAC directly. The only thing it does as a preamp is digitally adjust the voltage output, so it's giving you just as much accuracy as a passive preamp, with more precise control.
bidn
My setup:
Thanks!
Denafrips Pontus
Schiit Yggdrasil
As a desktop alternative to the Hugo 2,
I recommend RME ADI-2 Pro, a DAC-amp which can be found at about at about € 1600 in Europe, should mean less than US $ 2000./
It is extremely dynamic, fast and detailed, for example when I compared connecting the Utopia directly to their integrated amp,
and with connecting the Utopia to the iFi iCAN Pro driven over 2x high-end XLR by the RME, there is clear loss of detail, etc.
However if you want a smooth, warm coloration, this will not be a good choice as it has no coloration and is very detailed.
doraymon
I just ordered a Holo Audio KTE Spring DAC... Can't wait now to see if my choice was good!
You won't regret it for sure
forestitalia
- Feb 21, 2014
This RME is an intriguing Dac-amp, how it works with other cans?
bidn
I assume it would not work well for electrostats which require special voltages.
Giving some examples with other cans from mine:
1. my LCD-X:
to spare my ears I try to listen at the lowest volume levels, and at very low levels,
before having the RME, my LCD-X used to be muddy (e.g. with the iFi iCAN PRO, unlike other hps) and I had to listen to them at a higher level to get a proper SNR.
Now with the RME another wonder: even at very low levels the LCD-X are now clean and a have fine SNR! What a nice and unexpected surprise!
2. my HD 800:
perfect! No need to say much as you can find many experiences on this pairing on the internet, HD 800 owners calling it "endgame".
3. my Sonorous X
These are the opposite of those other cans above (which require a lot of juice) as these Sonorous X behave like very sensitive in-ears and most amps have too much juice for them, driving them with my AK240 was much better.
Again a nice and unexpected surprise, the RME drives them perfectly!
So it can drive perfectly from ultra-sensitive cans to very demanding one by simply turning the volume knob.
In general with the default settings of the RME the sound is full-bodied, transparent and clean but not artificially warm or lusher than it is in reality .
I like it like this, but I understand there are some filters which would allow for a warmer and lusher sound for those who prefer it.
If I had had the RME first, I wouldn't have bought the iFi iCAN PRO.
I assume the RME doesn't get enough attention among audiophiles
because they are a pro (studios, recording) company and not an audiophile one,
so they are hardly known among audiophiles and I assume they don't sponsor Head-Fi, don't advertise in the audiophile community
Re the Hugo 2,
watching Currawong's youtube video on the Hugo 2, part 2, where he says that the Hugo 2 doesn't scale to the Utopia,
besides the issues that the Hugo 2 cannot be stacked and is too big for my pockets, helps me pass on the Hugo 2.
I would prefer to buy a SP1000 (ideally an upgrade or a successor with several micro SD slots) which I could use in bed or carry along.
forestitalia
- Feb 21, 2014
Interesting. At the moment I'm pretty happy using an AR-M2 as dac amp, to my ears is phenomenal with Utopia. Had the Hugo , but didn't like that much.
