HumanMedia
- Jan 23, 2006
Finaly, my Qutest bought.
offcourse in a local, 40kms from here, Headphone Specialist.
It is on for a day to break it in. We want the best, don’t we.
Now, I’ve read this entire topic but my memory is to bad so I’ll ask this (again).
How do you all coop with the bnc connections?
Chord thought about everything but why they used these difficult connections is not clear to me at all.
So how do you use your coax to the Qutest?
thank
The BNC are the correct connectors for coax as they match the characteristic impedance of the cable. The RCA connectors are the inferior ones and create reflections in the cable. If your source only has RCA then as others have suggested use an RCA to BNC cable, try and avoid adapters. And the cable needs to be proper 75ohm coax as well, but it doesn’t have to be pricey to be good quality, check out a Belden 1694 made to the right length with whatever connector you need from bluejeans cable, it may be all you ever need.
https://www.bluejeanscable.com/store/digital-audio/index.htm
