jlbrach
- Jun 4, 2005
you will likely want a good high quality amp if you use the abyss TC or Susvara or LCD-4 for that matter
Thank you. Right now I'm using my Dave as a preamp. How do you hook up your Dave to a headphone amp and a power amp? I wish the Dave had fixed outputs for a headphone amp, and variable outputs for a power amp. But it seems I have to choose fixed or variable output for both amps.you will likely want a good high quality amp if you use the abyss TC or Susvara or LCD-4 for that matter
Guys, question for you. Right now I have the Focal Utopias, which are fantastic, but I think they may be a little polite for my tastes. Does my Dave/M Scaler combo have enough power to run the Abyss Phi TC directly, or is a headphone amp necessary? I'm hoping I can get away with switching headphones (to Abyss or something else) rather than adding an amp and headphones.
Thanks in advance.
Thanks in advance.
So to Triode, I did test the cross feed on Dave and it does show up as zero as expected. Just to confirm this is off correct.
Thanks guys for your replies!i ran my TCs direct from Dave/MSc for quite a while before I added a Formula S/Powerman and was quite happy. Once in a while I switch back and am not disappointed. It still sounds mighty fine.
Hi, two stupid questions.
Dave jas 6.35 or 3.5 mm. jack?
It is possible to connect android phone via otg adapter?
Thank you
thank you. about android i have usb audio player pro on my lg, therefore i also use the player in bit perfect modeDave has a 6.3 mm headphone jack
It should be possible. I connect my Samsung S7 to Mojo with an OTG adapter. The only problem is that Android audio up-scales all audio irrespective of the original sample sample rate to 192 kHz 24. Unfortunately this can't be turned off. It isn't very transparent, and smooths the sound and reduces dynamics. I purchased an app, USB Audio Player Pro. This can be configured to output bit perfect native sample rate. USB Audio Player Pro also supports Qobuz for streamed content. Offline Qobuz content is not supported.
