Does anyone feel that the brand/quality/cost of RCA cables to DAVE will change perceived SQ? Any recommendations?
@Triode User has already provided an answer, but I would like to take this opportunity to extend the ethos of his comment.
Nick already has several years experience with eliminating RFI for cables carrying the digital signals.
The question of the best cables for carrying the analogue signals does get occasionally raised on the chord threads, and in the wider terms of RCA, headphones, speakers, because each case will be susceptible to RFI.
Each time, some owners swear blind that the more expensive a cable (or brand) the better, whereas others swear blind that cheaper cables perform much the same.
I think that Nick is right to point out that some cheaper cables can be just as effective.
The key to understanding why, becomes the interesting knowledge, because it will help explain why brand A works well for some owners, and brand B works well for other owners.
@Rob Watts does post occasionally about cables, and it becomes clear after reading a few of them, that owners need to understand the 'design ethos' of cables before throwing thousands of dollars at a favoured brand, then experiencing disappointment.
The design ethos includes:
- Include a shield that is not connected at either end - designed to dissipate RFI as heat within the shield
- Include a shield that is connected to ground/earth at one or both ends - designed to remove RFI to earth. Maybe not the best solution if a system is completely non-earthed. You are probably just shunting RFI into the ground plane of your electronics.
- Use widely spaced conductors, so as to reduce the impact of crosstalk between conductors - the approach used by one manufacturer of recommended speaker cables.
- etc
So there is not one cable design ethos that is the best for all Chord owners. They need to think a bit deeper about how they have set-up their own system, especially with regard to earthing etc. This is bad news for anyone focused solely on the Apple 'just plug it in and it will work' philosophy.
I hope that this does not contradict Nick, but when owners buy DAVE and similar, I believe it is worth the time to step back and consider their overall audio system, rather than buying a brand/design of cable that 'destroys' what they have just spend a lot of money buying.
