where are you based? Also did you buy new or used. Can you give us a clue on the ‘great price’ intrigued.
+1 at least the difference in percentage...
Is it worth getting a separate power supply ?
Has anyone done this ? If so was there a noticeable difference ?
Yes, Chord's website has been down for sometime.Is their website hacked!?
It refers me to a weird survey every time I enter.
Do you think maybe trying to upload a 2Go launch announcement broke it?Yes, Chord's website has been down for sometime.
The site is back up. And I would hope that isn’t foreshadowing a rough start for the 2Go like the Poly.Do you think maybe trying to upload a 2Go launch announcement broke it?
Try BNC three and four on the DAVE.I just upgraded my TT2 to a DAVE, but I'm having big problems. I hook both BNC inputs up from the M-Scaler to the DAVE and the sound keeps cutting in and out. When this happens the screen on the DAVE flickers and goes on and off, and I just hear the music cutting in and out.
Does anybody know why I'm experiencing this issue? If so, how do I fix it?
It happens on 1 and 2 and on 3 and 4. It's cutting in and out and makes a static noise sometimes. It sounds like a pop and crackle from a vinyl record. The TT2 worked just fine with the M-Scaler. I guess I'll keep trying. Thanks for the helpTry BNC three and four on the DAVE.
It's even worse with just one BNC cable. It just cuts in and out and in and outTry one BNC cable at a time on HMS, and cycle through 1-4 on DAVE one input at a time. Try with both BNC cables. That will help isolate cable issues (connectors, etc) and which DAVE inputs may be more stable.
if each cable and output and input works great, try swapping 1-2 (or 3-4) on DAVE to see if that helps get a stable sync (DAVE syncs DX differently than TT2)
if you have an intermittent connection, you will hear something similar to what you’re describing (not saying that’s the issue, but that it may be helpful to isolate your testing to see if it is)
I tried the stock BNC cables and had the same problem as using the SOtM BNC cables.Have you tried different BNC cables to see if that is any better? Or a long shot, do you have any other equipment nearby apart from the Mscaler?
