jscmd2000
- Mar 21, 2017
Does anyone have any experience with Pass Labs HPA-1 as hp amp for the Dave?
Yes, I spent some time with the Pass paired with the blu2/dave at our last mini meet. I used Utopia's, Clears, he1000's and abyss phi's. I did an a/b between the pass and the cavalli liguid gold and preferred the liquid gold. Wider soundstage, more air and separation. Both amps are impressive and showed control and extracted detail from all the phones I used, but to my ears the cavalli was the clear winner.Does anyone have any experience with Pass Labs HPA-1 as hp amp for the Dave?
All of the phones were great directly out of the Dave, especially the Utopia. Using the he1000 v1 and abyss, I preferred the addition of the cavalli.How additive was it over the amp built in to the DAVE?
Still, in my opinion the best sound was blu2/dave -> xlr -> Blue Hawaii SE -> Stax sr-009.How additive was it over the amp built in to the DAVE?
IPad Pro is bit-perfect with Tidal app, or you can use the Onkyo HF Player to play hi-res content/DSD bit-perfectly. I have never tried using it as a Roon endpoint though but I’m sure it’ll be bitperfect if that works.Does the ipad pro upsample to 48kHz? If so is that an issue with tidal? i assume as an endpoint with roon it stays at 44.1khz?
Would optical imac to dave solve all the above mentioned issues?
Finally how does dave improve on TT if anyone has an idea?
DAVE and TT2 (and I think TT) have the same second-order analog noise shaper. The difference is in the digital noise shaper.Many thanks ecwl. Doesn't dave have an inferior noise shaper to TT2 which has the a second order analogue noise shaper unless i'm mistaken? What is the real world listening sensation dave to TT ie what do you feel?
