I am thinking of selling my band new high efficient 98 dB Omega speakers that can be powered by Dave or Hugo 2 directly to get myself a Dave.
Decisions, decisions
To be clear I meant on a like for like basis. ie comparing a cd played on Blu2 with the same redbook file streamed to Blu2.
It is not always easy to be sure that CDs and high res versions of the same recording have come from the same master. This makes it difficult to compare redbook and hi res files on a like for like basis.
This thing also has more than enough juice for my Abyss Phi, so looks like I will likely be selling my Moon Neo + Yggy!
Good idea. I sold my Yggy and Moon 430HA and haven't looked back. Big thanks to Chord for including a top-notch headphone amp in the DAC. Anytime we can simplify our system is a big win.
SuperBurrito, did you try the DAVE + the 430 before you sold the amp?
Question to DAVE owners.
Would either or both of these help me?
I have heard I might not need anything because the DAVE does such an incredible job with USB, but figured it couldn't hurt much to ask.
- iFi iUSB Power - extremely low noise USB power supply that replaces the noisy power coming from most USB sources.
- iFi iPurifier 2 - data re-clocking and conditioning from source to DAC. USB 3.0 Female B in, USB 2.0 Male B out. Please note that USB 3.0 B socket is backwards compatible with USB 2.0 B so you don't need a USB 3.0 cable.
I went to the iFi stand at a canjam, told them I had a DAVE and asked them which of their products could help me achieve a better level of performance in my chain. The diplomatic answer was quite long as to the capabilities of the DAVE vs iFi products but my take-away from the diplomacy was that iFi products could not help me where a DAVE was involved.
Regards
GG
If you can try an optical cable from your digital source into DAVE, then try that. Make sure to disconnect the USB cable while you listen to optical.I have heard I might not need anything because the DAVE does such an incredible job with USB, but figured it couldn't hurt much to ask.
If you hear an improvement, then you should consider putting lots (20+) of ferrites on your USB cable.
The aim is that the USB cable sounds the same as the optical, as the optical input on DAVE is the reference for sound quality.
I suggest you try it.Wait, hold on.
So if my PC has toslink out you're saying I should use that with Dave instead of USB?
The sound quality of the optical input on DAVE is the best because of the perfect galvanic isolation (as long as the optical connection is the only digital input connected to DAVE). So any problem that exists with your USB source or cable will be revealed by comparison with the optical connection. You may not hear a problem with the USB connection though.
If you prefer the sound of optical then you can continue to use it, but bear in mind it won't support all the digital formats that USB supports. So music at sample rates above 192KHz is an example of music that doesn't work through optical. In my system the optical connection also won't support 88.2KHz. But that's a problem caused by the computer, not by DAVE or the cable.
If you want to maximise the performance of USB you should try ferrites. The result should equal optical.
Now playing: Piano Magic - The Canadian Brought Us Snow
Thanks for the impression Draytonklammer. 'appreciate it.
