jlbrach
- Jun 4, 2005
that is very good to hear,i am pleased...i look forward to giving them a workout tomorrow when the dave arrives
When that distortion is on the level of the Stellaris... yes! I want!
Nothing sounds like live unamplified music. The gap can never be closed. In which case, in the spirit of genuine enquiry: what should we be listening for? It's a question I've asked myself many times to which I've never found a satisfactory answer, other than that the music connects with me to an extent that I don't mind the gap.
This just really cracks me up after a long work day. Even though it seems to miss the point. Still super hilarious to me. Not sure why.
My simplistic interpretation of what Rob Watts and John Franks have been saying is this. If you build a DAC (Pulse Array + other design aspects) that is innately significantly more immune to jitter than any other DAC designs, a great clock that's good enough would be perfect. If you build a DAC that is innately more susceptible to jitter, you may try to get some sort of super clock to minimize the jitter. However, since you're not sure what you're doing, at some point, your super duper clock is not really helping with jitter and is just injecting noise into the system and altering the sound that you may think is better.
With all that said, still a hilarious joke.
I buy all of this, but why aren't the DAVE then miles better than the dcs Vivaldi / Nagra HD or even the Select II who are using jittery super clocks then, it is just a subtle difference and down to a matter of taste is what Roy concluded for example?
Is it because of the weak recordings that cant show of DAVEs full potential maybe, or how can the "poor-knowledge-ultra-expensive heavy-jittery-dac's" sound so close to DAVE then? In my book they should have sounded much worse, or does DAVE also got a small hidden secret bottleneck in the design that you struggle with to make it fully bloom out properly Rob?
@romaz, thanks for putting up your thoughts.
1) What is the rated sensitivity of your alnico loudspeakers?
2) Were they connected directly to the headphone outputs or other output on the Dave?
3) Was the volume adequate for musical enjoyment? A poor man's super desktop system maybe?
To me it's absolutely not a subtle difference but night and day and I get perplexed that people can't hear it as vast differences.
Rob
Really looking forward to the first recordings from DAVINA........![]()
Listening to Metallica (Black album) - on Mojo, amazing !!!!!
I will be doing some initial recordings to mostly test for depth - I plan to have two prototypes, fed with the same mic feed, so I can change the internal configuration and see if noise shaper resolution is the same for DAC's and ADC's - they should be. So this will be natural sounds in my Welsh village - dogs barking, birds, etc. I will test for sounds that are several miles away to close up.
Also, it will be home recordings of guitar and a few other instruments, again with two units with differing internal settings - how else can one do AB testing with an ADC? The other issue is transient reproduction, timing and how this relates to decimation, which is currently very poorly done. I am currently thinking about the best way to consistently and reliably do this. Percussion comes to mind as the best way to do this.
The next stage is to release to professional engineers, and here we have a number of big names lined up, so I won't be dependent on my inexperienced efforts. These recordings will be used for final decimation testing as I will record at 768 kHz then post recording convert down to 44.1 16 bits - and having the original 768 k on hand will be very interesting.
I will be posting more about this once the PCB is finished.
Rob
Me too! Actually, I'm very interested in the test recordings Rob has mentioned he wants to use, some everyday things. I personally would REALLY want to listen to that on the DAVE. I hope Rob can share these.![]()
Rob
