rkt31
- Oct 14, 2014
let's be clear. hqplayer is only a processor while dave is much more than a processor. the hardware which converts the processed stream to analog is equally important which in dave is very unique. I do not agree to the claim that hqplayer needs a FPGA for heavy processing capabilities of it. may be the people converting pcm to dsd512 that too in multichannel in hqplayer might need more processing power but that is not applicable for dave as it is 2 channel device and imho will not benefit from pcm to dsd conversion ( I have not experienced but imho people converting pcm to dsd via hqplayer might have penchant for certain flavor of sound) I have lenovo laptop with i7 4th gen processor which only uses 7% processing power while upsampling 16 bit 44.1khz to 24 bit 192khz using sinc filter( sinc uses most processing power) so for a 2 channel pcm to pcm routine even a normal laptop is sufficient indicating that hqplayer is just another resampler with more options. having said that I found hqplayer resampler much better than j river, foobar etc. coming to dave, imho it has much more sophisticated upsampling and noise filtering which can't be matched by hqplayer as there are many factors. hqplayer has the limitation of highest sampling rate, number of taps and accuracy of volume control as compare to dave. dave upsamples and filters at much higher rate and volume control is also much more accurate as it is embedded in the processing of dave ( more can be told by Rob). so the kind of processing dave has , hqplayer currently does not have .as mentioned earlier, before conversion to analog ,the digital stream has much more resolution and data rate in dave which is in mhz and might not be supported by the current pc hardware . also even if hqplayer author redesigns the algorithm, this processing in mhz can't be streamed in real time due to limitations of parallel processing with current processors in pcs .
