I have just spent last night and this morning listening and comparing Roon direct to DAVE vs Roon to HQ Player to DAVE and have been listening to a variety of 16/44 PCM, 24/192 PCM, DXD, DSD128 and DSD256 files that are very familiar to me. I have also tested Tidal streaming through HQ Player, something I did not realize was possible. This is my first time to experience HQ Player with my DAVE, Esau, and so this experience is brand new to me. It's been a long time since I've used Audirvana and so I cannot make any comments on how it might directly compare.
Here is my schematic that another user suggested and that Andrew Gillis has endorsed. Obviously, in my case, substitute my DAVE for the PS Audio DirectStream. HQ Player is running on my Windows machine, Roon Server is running on my sonicTransporter and the microRendu is running in Roon/HQ Player/NAA mode:
Here are my early listening observations:
PCM files:
With no upsampling/filtering and no dithering, Roon alone vs Roon/HQP sound identical. Even in my system that I consider to be very resolving with all of my HF cables, I cannot tell a difference.
With no upsampling/filtering but with TPDF dithering enabled, there is a noticeable difference in favor of Roon/HQP. Both sound very good but with TPDF dithering, my 16/44 files come to life more. Transitions are more authoritative and there is better layering. There appears to be more air around voices and instruments also. I am hearing no downside with HQP in the chain and the signal being fed to the DAVE remains bit-perfect. The partnering between Roon/HQP/microRendu is seamless. Obviously, much testing and configuring have been done by Roon, HQP and Sonore to enable this seamless compatibility. The delta is not huge but there is no need to blind test as the difference is fairly clear.
With upsampling/filtering turned on, it sounds good but not as good as with it off. There is a definite loss of depth. DAVE clearly upsamples better than HQP even when I upsample to 768kHz PCM or DSD7 256+FS.
DSD files:
With upsampling/filtering off and dithering off, once again, I hear no difference.
With upsampling/filtering off and dithering set to TPDF, once again, Roon/HQP sounds a bit better.
With upsampling/filtering on, once again, it sounds slightly worse. I even transcoded to PCM 768kHz since DAVE is a superior PCM DAC and native DSD sounds better. Definitely, leave your file in its native format.
There are other dither modes I will need to test but TPDF seems to be a good way to go.
Based on these early observations, it would appear to me that HQ Player used as a player without any oversampling or filtering but with TPDF dithering is superior to Roon by itself (to my ears) with the DAVE. I would agree that upsampling should be left to the DAVE and I find no advantage to transcoding from one format to another. HQ Player without Roon suffers from a clunky and unattractive interface and would be much less enjoyable from a usability standpoint without Roon. Roon + HQ Player + mR in NAA mode seems to result in a definite improvement. Unfortunately for me, another expense.
As a side note, if you wish to use HQP with Roon and your mR, you cannot use ASIO or Wasapi as a back end, you will need to use "Network Audio Adapter". This means you can't utilize Chord's native DSD option but DoP seems to work just fine.
