Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
....speculating that the lack of air might correspond to a lack of ringing and that dacs based on a Sigma-Delta chip might create a false sense of air and space....
I have been asked this before that somehow the extra depth of my DAC's - and most particularly with Dave - was due to something added within the design. Now it is very easy to create a false sense of depth by simply adding reverb, and this of course may be done easily with the resources one has on a big FPGA. But I can prove this is not the case - simply by using flat as a pancake recordings. So Jazz at the pawnshop, is in a small venue, and should sound like it has little depth - and that's exactly how it sounds on Dave - it sounds like a small environment. When you use close miked recordings that have no added reverb it sounds completely flat, that is the sound is exactly in line with the speakers. Now if I had used some tricks to artificially enhance the depth, then everything would have more depth all the time. But this categorically does not happen with Dave - flat recordings that have no depth, has no depth, instruments that have depth will be accurately portrayed with depth.
This brings me on to the most important point about subjective evaluation - to know something is better for sure (that is its not some kind of system optimisation) is variability. Then one can be sure the improvement is a fundamental step forward in transparency, rather than some fine tuning that suits the product at that time with that particular system. So I am trying to maximise the range of depth that can be heard, from completely flat to sounding miles away. And in this sense, Dave is much more varied in depth perception than any other DAC I have ever designed - by a massive margin.
The technical reasons why depth is compressed in DAC's I understand, and its absolutely nothing to do with ringing or time domain behaviour (this will affect lateral imagery and height though) but is down to how accurately small signals are reproduced. Small signals are normally distorted, and have an amplitude that is modulated or changes with level. It's these tiny changes in amplitude that confuse the brain that stops one perceiving depth properly.
The interesting thing I learnt with Dave is that there is no limit to how accurate small signals need to be for the brain to properly perceive depth. This is actually quite an amazing and surprising statement; normally you can get to a limit where reducing a distortion or error no longer has an effect; but - and this is the stunning thing - this does not seem to apply about depth perception. There is something truly amazing about how the brain accurately resolves and measures depth.
Delta-sigma DAC's fundamentally have the capability of resolving small signals much more accurately than R2R or ladder DAC's as ladder DAC's are poor for small signal accuracy due to the impossibility of matching the resistors. Having said that, delta-sigma is not a panacea, to actually resolve depth properly requires a lot of care and effort, as minute errors will have an effect.
Its way too complex to talk about all of the issues involved in DAC design to properly resolve depth information, I think I will talk about it in a future blog article.
Rob
